Rotors
Old Feb 26, 2006 | 09:48 PM
clawhammer's Avatar
Wouldn't aftermarket pads like Cobalt GT-Sport with OEM rotors be ideal for mostly street driving with occasional track usage?
Old Feb 27, 2006 | 04:45 AM
jakub2000's Avatar
Originally Posted by SaltyDog,Feb 26 2006, 12:40 AM
Slotted rotors tear up your pads. Drilled rotors are fine as long as they are casted with the holes rather than drilled after the fact. Also, the reason they crack is due to tremendous heat and pressure caused from track driving. They would be fine on the street, but then again, if all you do is street driving and a little track, then oem's is the way to go.
I went for Spoon front drilled rotors because I used to track the car. However I drove it on the track only once since the isntall and put 10K mile on the street on them.
Each and every hole cracked north and south, so there goes the QUARANTEE from Spoon how good their rotors are and how they do not crack
I use stock pads for your reference and only street&auto-x her.
Old Feb 27, 2006 | 04:50 AM
jakub2000's Avatar
BTW. OEM rotors and pads are just fine...but track them for more than 3 laps and you will find out that the street is the only place to use them...as long as you don't track, OEM is more than fine
Old Feb 27, 2006 | 08:36 AM
wanabe's Avatar
drilled and slotted cad plated, for looks not for track-
from duc at spugen... he installed them backwards so that they dont dust.
look much better and with the stock pads, no dust:
Old Feb 27, 2006 | 08:44 AM
VAD's Avatar
VAD
OEM rotors+Carbotech pads+DOT 4 fluid=Very good on track.
Old Feb 27, 2006 | 09:06 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Soon to be this:
Old Feb 27, 2006 | 09:14 AM
S2kracka's Avatar
OEM rotors and some good pads are a great option. I personally like Porterfield RS-4 pads with zinc-dipped OEM rotors to prevent hat rusting.
Old Feb 27, 2006 | 09:31 AM
04RioS2k's Avatar
wanabe what you mean by installing them backwards?
Old Feb 27, 2006 | 09:36 AM
mikegarrison's Avatar
The slots are directional.
Old Feb 27, 2006 | 11:11 AM
CharT's Avatar
Actually, slots on slotted rotors aren't directional. It's just the cooling vanes that may be directional. Vented rotors typically have either radial vanes or directional vanes. If they have radial vanes, it doesn't matter which side of the car they're mounted on. If the vanes are directional, then you better make sure the vanes are oriented properly and the direction of the slots are dictated by that.
High performance rotors are always directional vaned so must be mounted on the correct side of the car. Solid rotors that have slots can be mounted on either side, whichever looks better to the owner.
