Rubber(Foam) Enforced Frame
Old May 27, 2004 | 10:28 AM
BlitzSRM's Avatar
I just recieved a japanese video i got from eBay.
Its mostly about the S2000. But there was an additional section in it which compared a bunch of tuner GTR's. Each tuner had their own approach to modifing the car.
Anyways, according to the driver one of the cars was suprisingly stiff. So they had a side scene discussing the how they made the car so much stiffer.
They said rubber (translation at least) looked like foam. They demonstrated it with a plastic tube. They mixed a small amount of a 2 part solution, and shortly afterwards it dramatically expanded. Then they showed another tube fill with the rubber (foam) dried. It was super stiff. as far as weight i don't see it weighing more than the bottle they used.
Then they went to the car, opened the passenger door, and showed the holes they drilled to fill the door sill.
They noted that they foam can be bought from any reputable tuner shop (i guess in japan). The translation didn't show any brand, and they didn't show any bottles with labels.
Has anyone heard of this type of modification? Is there any down side? (like corrosion). If you do know about it where is it sold? and how much does it cost?
Old May 27, 2004 | 12:01 PM
Big Ben's Avatar
You can buy this foam possibly from a home supply store. I'm not sure of how much it may help stiffen the chasis. But carbon fiber wrapped foam cores are very strong and stiff in air planes and such.
Old May 27, 2004 | 12:52 PM
BlitzSRM's Avatar
Big Ben,
Do you know what its called? It was a 2 part mixture.
Old May 27, 2004 | 01:10 PM
JDMwhore's Avatar
This is one kind:
http://www.tapplastics.com/shop/product.php?pid=79&
Old May 27, 2004 | 01:28 PM
kitwetzler's Avatar
be really careful. expanding foam has a tremendous amount of force. I found out the hard way.
Old May 27, 2004 | 01:31 PM
JDMwhore's Avatar
Yeah and it is messy as hell. It will take weeks to get it off your hands and nails if you get some on you.
Old May 27, 2004 | 01:41 PM
BlitzSRM's Avatar
kitwetzler,
you actually tried it? What happened? and What is worth it?
Seems like a simple mod to do. But the volume must be calculated preciesly.
Old May 27, 2004 | 01:42 PM
BlitzSRM's Avatar
JDMwhore,
Thanks, I'll wear gloves if i do decide to do it. but right now... no plans. just curious about it.
Old May 27, 2004 | 01:43 PM
kitwetzler's Avatar
Yup, I broke some body panels on my NX2000 when I was trying this.
it definitely helps, just be careful.
Old May 28, 2004 | 01:21 AM
tru's Avatar
tru
ive seen it done before. its not regular expaning foam. i dont know what its called but it doses not expanded as much as expanding foam
Xeon
Nov 9, 2016 01:06 PM
ben5560
Apr 2, 2016 08:04 AM
sillyboybmxer
May 29, 2010 04:14 PM
Mike VR6
Apr 7, 2008 12:31 PM
LubedKoala
Oct 2, 2006 04:04 PM
