S2000 2.2L/2.0L Power Output vs Speed
[size=1]Originally posted by Deslock
One other thing I want to point out from your post is that same RPM, higher torque = faster acceleration only for a given vehicle speed (i.e if you compare two situations with equivalent RPM and engine torque values, but different vehicle speeds, acceleration will not be the same).
Originally posted by 2kturkey
What I want to see is whether I just touch the accelerator a little to maintain speed in the 2.2 compared with having to give the 2.0 plenty of gas, for example.
As you mentioned, you really can't tell from any curve what this will be like. But I have no reason to think the 2.2 would be much different from the 2.0. Except that at a given rpm, you'll have more torque available, so you should feel that extra margin. Bottom line, I can't say, but I suspect it'll be just that much more driveable. Let us know what you think when you drive one!
regards,
Dave
Originally posted by STL
Or the car really has slightly less than 240HP at 7800rpm -- that would also explain the HP and torque numbers not mathcing up.
Frisky
Aug 1, 2007 03:26 PM
