S2000 engine rotation---> Need help
Old Nov 1, 2005 | 05:43 AM
lotus7racer's Avatar
Default S2000 engine rotation---> Need help
Currently owned a Lotus Super 7 (950lbs) with Hayabusa turbocharged engine. I think I blew my engine @ 405hp run.
http://mjmturbos.com/images/busalive2.avi
At this point, just contemplating to use my S2000 engine. Without knowing anything about this engine, I heard the engine rotates different than traditional car.
3 Questions---> if I'm setting in the car, Is the S2000 engine (driveshaft) rotates clockwise?
If it is, my cosworth differential will not work, the car will move backwards.
Do you think I might have to use the S2000 differential instead of my Cosworth?
Is it possible to put a" little" (8-10psi) boost without changing fueling system and some internals?
Thanks a million
One lost Lotus
Old Nov 1, 2005 | 05:58 AM
triumph87's Avatar
Sorry Ii cant answer your question but sickk car.
Old Nov 1, 2005 | 06:08 AM
PilotSi's Avatar
Thanks a million
One lost Lotus
The older Honda engines spun CCW, but I believe the F20C is the first to have spun clockwise. The rest of Honda's line up also spins CW now, so this shouldn't be a problem.
You can probably still use the Cosworth diff if you can get the driveshaft to bolt up.
And I think the stock fuel system is pretty maxxed out for boost, but I could be wrong. Someone can probably answer your last 2 questions better then me.
Good Luck.
Old Nov 1, 2005 | 06:21 AM
Cyclon36's Avatar
Don't know about the rotation, but you can bolt on a comptech supercharger with 5lbs of boost with no changes to the internals. Some have even run 10lbs with no changes to the internals with good results. I wouldn't go anything over that without getting some sort of internal reinforcement or lowering the compression.
Old Nov 1, 2005 | 06:33 AM
Dave-ROR's Avatar
The S2000 engine rotates like a normal engine. Only older hondas were CCW.
Old Nov 1, 2005 | 07:12 AM
Good Luck.
Thanks guys....really appreciate those tips. I am glad I can still use my Cosworth differential.
A guy from New Zealand emailed me, he said not to turbo the engine. The current setup is already too diabolical and no need to put more power. Its a waste since the car only weigh in at 950lbs.
He said, it can beat any supercar in the world including the Porsche GT3.
He has the same as mine he uses S2000 engine (aspirated).
http://autospeed.drive.com.au/cms/A_1344/article.html
Well, another question... what do you guys do to upgrade the power just a "little bit'
without turbocharging?
Old Nov 1, 2005 | 07:19 AM
jwa4378's Avatar
You can always use more power.....if you can put it to the ground. If not, its kinda pointless.
John
Old Nov 1, 2005 | 07:26 AM
John
I will take care the ground hook-up. Give me the quick run down and I will not bother you guys again. I do appreciate all the help.
maxx2k
Mar 1, 2019 05:05 PM
bonesXU1
Apr 20, 2013 01:08 AM
Oggers
Jan 16, 2012 11:44 AM
RobinBall
Sep 24, 2008 02:26 AM
