Is the S2000 Engine Truly Handmade?
Old Feb 14, 2007 | 05:24 PM
  #31
Ks320's Avatar
[QUOTE=papalegate,Feb 12 2007, 11:03 AM] This may be too much information, but here is a previous post I saved from another board member, offering a detailed history of the old Tochigi plant and a description of the extent to which the S2K was "hand assembled":
The S2000 was originally manufactured in Tochigi, Japan. The Tochigi factory complex is composed of three different plants: The Takanezawa Plant, 51,000 sq. meters housing 1,200 employees. Operating since 1990, it focused on the production of advanced niche models such as the S2000, NSX, and Insight hybrid vehicle. Also at the complex is the Mohka Plant, 58,000 sq. meters with 800 employees, operating since 1970, to produce engine and chassis parts for both automobiles and motorcycles. The third plant at the complex is the Haga Parts Plant, 6,900 sq. meters, 200 employees, operating since 1993, which is responsible for production of high-tech automobile components.
But through April 2004 the Takanezawa plant was place you would find the S2000. It was considered their flagship factory. It was originally created exclusively to build the NSX. The S2000 shared an assembly line with the aluminum-bodied NSX and Insight. Takanezawa was best described as a small-number mass-production custom factory where high-tech production technology and old-time craftsmanship come together. Rather than a heavily automated assembly line, the S2000 was constructed at a series of workstations by a number of teams.
Following an announcement in 2003, Honda closed the Takanezawa Factory and moved the entire facility to Suzuka Factory in May 2004. Honda said this was done to integrate production, with the engine assembly to the completed vehicle being performed in one location. However, insiders say is was also due in part to the lack of interest in the dated NSX which ceased production at the end of 2005 and necessary to free up space at Tochigi to produce more compact, alternative-fuel vehicles.
Outline of Suzuka Factory
Production capacity : (Completed automobiles)
No. 1 Line: 1,100 units/day
No. 3 Line: 1,100 units/day
New line: 60 units/day This is the line where the S2k and NSX and Insight will be built
Total: 2,260 units/day
Automobile engines : 2,260 units/day
Production models : Civic Series, HR-V, Mobilio series, Fit, Stream, Integra, Life
The Suzuka Factory was established in 1960. At the time of the transfer it had 7,300 employees and could produce 2,200 units per day. Production included Civic, Integra, and others. The new small S2000 line will produce 60 units per day raising the limit to 2,260 completed automobiles per day. Existing Suzuka Factory equipment was combined with the exclusive equipment transferred from Takanezawa Plant, making it possible to achieve small-volume yet low-cost production characteristics. The engine production equipment for small-volume models used by Tochigi Technical Center, Honda Engineering Co., Ltd. was also transferred.
The impressive front end of the S2000 is made with a 1,500-ton press machine to draw, bend, trim, and trim again, in an exact, precise method. In order to produce the strengthened chassis for the S2000, Honda developed a variety of new welders including custom hand-held welders for the X-frame-based body. In the original plant a track went along the ceiling that moved, plus it could raise and lower the bodies as they went through the factory. Again, in the original plant, with the exception of some welding and painting robots, the S2000 was almost 100% hand-built (assembly and installation). Aside from such unique features, uncompromising quality control and precise production were the pride of the factory. According to an S2000 owner who toured the Takanezawa plant, automation was limited to two spot welding robots that do some chassis welding and portions of the painting process. The cars were rolled around on independent jigs and the components which arrive at the factory preassembled are then hand-installed into each new car. It seems fair to say the car
Old Feb 14, 2007 | 05:25 PM
  #32
Ks320's Avatar
Originally Posted by Saki GT,Feb 13 2007, 09:52 PM
This robot had a bad day: http://youtube.com/watch?v=UQKk3PI-DW8
good one
Old Feb 14, 2007 | 05:47 PM
  #33
FISH22's Avatar
RED MX5, some great info, thanks!!
ST270
Jul 26, 2014 04:04 AM
energetic
Dec 5, 2005 02:05 PM
riceburner4life
Jun 21, 2003 08:28 AM
riceburner4life
Jun 20, 2003 01:37 PM
Ajjra
Apr 2, 2002 12:42 PM
