S2000 Launching Techniques
Old Oct 18, 2005 | 02:51 AM
Tolgahan Ures's Avatar
Default S2000 Launching Techniques
Hello everyone . How do u launch your cars? at which rpm? 4000 , 5000 , 6000 ???
and do u do it with revving to the rpm and the gear is inside one ; and do u only take your feet away from the clutch ??? If experienced drivers can teach this fully to us it would be great. Thanks for your help people .
p.s i want to launch my 05 s2k well because i had some problems with loaded 306 gti's and 330 ci's Thanks:::
Old Oct 18, 2005 | 04:26 AM
energetic's Avatar
I launch my S between 5000-7000 rpm depending on the road surface. Sometimes during shifts I just keep my foot on the throttle and sometimes I dont.
Old Oct 18, 2005 | 05:01 AM
switchcars's Avatar
ask WisconsinS2k....he is an expert launcher.
Old Oct 18, 2005 | 05:11 AM
S11LMX's Avatar
that is a very very bad habit to get into, you'll muller your clutch and damage the box too, I've heard of quite a few yanks that do that as they're not used to driving stick. It's not good at all
Old Oct 18, 2005 | 05:36 AM
CIVICTOS2000's Avatar
always try to launch above 5500 and if you spin to much try to feather the gas a li'l but not with the clutch b/c you'll burn it....if you launch below 5500 you might get it right a few times but when you don't and bog thats when you can get that rear end in a 1000 pieces.....BTW do a li'l SEARCH there is a lot of posts about launching......
D.
Old Oct 18, 2005 | 06:53 AM
4wheelVFR's Avatar
Rev up to about 6500-7000 rpm, and drop the clutch....quickly. You need to let the clutch up as fast as you can. I have only done it 3 or 4 times, but no nasty noises, no smells of burning clutch. Just make sure you don't bog.
Old Oct 18, 2005 | 07:14 AM
energetic's Avatar
[QUOTE=S11LMX,Oct 18 2005, 03:11 PM] that is a very very bad habit to get into, you'll muller your clutch and damage the box too, I've heard of quite a few yanks that do that as they're not used to driving stick.
Old Oct 18, 2005 | 09:29 AM
Nhan's Avatar
damn i've bog shit loads of time!! bad
Old Oct 18, 2005 | 09:33 AM
r_master78's Avatar
i am not an expert on launching cars, but dropping the clutch seems like a bad idea to me... maybe it is a bit different on RWD cars b/c you can spin the tires more easily (I come from 4WD background where dropping the clutch usually meants busted tranny)
i usually rev it up to the rpm the car produces the most torque
when the light changes, i let go of the clutch, but i make sure I don't just drop it... i let it slip *just a tad bit* and it is history from there...
Old Oct 18, 2005 | 11:10 AM
kayvan_pour's Avatar
Banned
This inst an awd car. You have to be carefull what you recomend to people. Slipping a stock cluth in this car is a very bad idea. Youd should always launch obove 6k rpm for "normal" conditions in this car. You need a little tire spin so there is no strees on the rear end. If you keep launching like that something will go eventually.
