S2000 Offsets
Old Feb 8, 2004 | 09:42 PM
dmpts2k's Avatar
Default S2000 Offsets
i was wondering if anybody knew wat is the smallest offset u can go on an s2000? for example 38 in front and 42 in rear. i want the rear to have a bigger lip so i dont know wat offsets to go with.
Old Feb 10, 2004 | 05:23 AM
3ngin33r1's Avatar
bump for you to get an answer.
Old Feb 10, 2004 | 01:14 PM
Scot's Avatar
i had 16*7 fronts with 35mm offsets..... the car was lowered and had a semi normal alignment.... they rubbed when you hit bumps and I did not want to take it to the track with them on.
i also had 16*8 rears with 45mm offsets and that seems to be about the limit on the back without rubbing.
You did not state what widths you wanted, so it is hard to answer your question........
Old Feb 14, 2004 | 07:48 PM
UT-RTFM's Avatar
I put snow tires on the rear (same size tire) of my MY04 using 17x8 inch Konig Verdicts, which turn out to have a 40mm offset. The tires do hit the fender on bumps, so we're going to 17x7 and a different tire size. Discount Tire (after not checking at first, apparently) is saying a 17x8 needs a 50mm offset.
Barry
Old Feb 15, 2004 | 02:32 AM
turbo_pwr's Avatar
The offset will depend on the width. If you have a particular rim in mind. You might as well list it. It's easier for me to look at what's available in that rim (providing it's listed on line) and tell you what will work. A big lip is going to require you to roll your fender. I doubt you'll ever get more then a 3" lip on the s2000. It's just the way our high offsets work.
dirttys2k
Nov 1, 2012 11:54 AM
UpTheMileage
Jun 19, 2006 04:54 PM
Type R / Si
Oct 14, 2005 12:21 PM
hatch4raceb16
May 21, 2005 03:22 PM
Mutlu
Mar 15, 2004 02:00 PM
