S2000 "secrets"
Old May 24, 2013 | 02:01 PM
  #61
TVPincDoc's Avatar
Originally Posted by CMK
Originally Posted by Jax2k' timestamp='1368023463' post='22527837
If you double tap the hazard light button, pull on the e-brake to exactly 3 clicks, tap the gas pedal, and clap you hands 2x's the car will transform into a Decepticon.
Accidentally pulled e-brake to 4 clicks instead of 3. Car turned into a Pontiac Solstice. pls help.
This alone should be worthy of a recall-if not the beheading of whoever is responsible.
Old May 24, 2013 | 02:03 PM
  #62
TVPincDoc's Avatar
Originally Posted by s2ka
1. No matter how many times you try shifting to 7th gear on the freeway it never works.
I try this almost daily since having purchased an e90 M3. Both cars crave that extra gear, but only one has it.
Old May 27, 2013 | 09:26 AM
  #63
pa9k's Avatar
The top latches are perfect sunglasses holders.
Old Jun 1, 2013 | 10:17 AM
  #64
homersapiens's Avatar
OK, here's something new.
I discovered a red wire tucked up under the far left of the dashboard (left of the drivers leg) with a toggle switch on it. It's obviously not OEM but I have no idea what it was meant to do. The car starts regardless of the toggle position, but that's all I have tried.
The previous owner is not talking. Any ideas?
Old Jun 1, 2013 | 11:04 AM
  #65
Wolf95's Avatar
LMAO!!!!!
Old Jun 1, 2013 | 01:34 PM
  #66
BlakeNFR's Avatar
Probably something related to the audio system the previous owner put in.
Also discovered today, that if you put the top down and your iPhone on the passenger seat, it will overheat.
Old Jun 1, 2013 | 05:06 PM
  #67
xviper's Avatar
I had 4 switches mounted under the dash of mine. They each did different things and were personalized. It's somewhat ridiculous that such a question would get a legitimate answer on a world wide forum. You just have to get under there and trace the wire yourself. It may have been cut a long time ago and the switch does nothing.
Old Jun 1, 2013 | 06:30 PM
  #68
cosmomiller's Avatar
Top Answer: 1
It is from the Honda optional IPRD (Involuntary passenger removal device) passenger ejection seat.
Old Jun 1, 2013 | 07:27 PM
  #69
pa9k's Avatar
This thread is called s2000 secrets, not HELP I CAN'T FIGURE OUT WHAT THIS SWITCH THAT DOES NOTHING DOES!!!
Old Jun 1, 2013 | 09:39 PM
  #70
Originally Posted by cosmomiller
Originally Posted by xviper' timestamp='1370135201' post='22580941
[quote name='homersapiens' timestamp='1370110622' post='22580462']
[/quote]
I wish.
I also have a problem with sunscreen stains on the passenger side door from the last time I took my wife with me on a drive. She also gets motion sickness. It won't happen again.
