S2000 Suspension Issues
I had a similar problem once, I needed new rear tires, so i went to a tire shop and asked for the same tires I had on the front Kuhomo SPT, but they put on Kuhomo AST, this is an all season tire, as soon as i got on the freeway (dont worry internet police) at around 50mph it all felt loose, and by the time i reached 65 (i never speed)(lol) it was downright scary. I took it back and they put on the right tires and all was good. I dont know if it was just having the all seasons, or the mix of summer in front and all season in back. But it felt like what you are describing.
I think it's possible that you will need to replace the front tiires also. I know that the tread is still good but the wear pattern on the interior and side plys may be affecting the handling. I suggest you replace the two front tires and use the old ones as spares.
Originally Posted by civicej8,Feb 28 2010, 09:26 AM
man, everyone here has gone 100mph. they are hipocrites if they say they havent. are you completely sure that the alignment is within factory specs? you should post up your specs.
I want to LIVE, legally drive, and be able to afford payments, because i don't have to cover $200+ speeding tickets.
The tires are different from front to rear. The fronts are Goodyear, and the rears are Federals. Sounds like there is a good chance this could be part of the problem (especially since the fronts were not replaced). I think I am going to buy the recommended factory brand of tires for all 4 corners and just keep or sell my other ones. I will check out the alignment specs and post them (but when I looked at them, they all looked ok according to the service manual).
I had OEM front tires and PS2 rear tires in stock sizes and my car was fine. Near the end of the rear tire life (28K miles) I could feel a lack of grip. New tires are PS2 in 225/45/17 and 255/40/17 - there are no issues with tracking/stability.
Thanks. I know factory size for a 2004 is 215/45/17 (front) and 245/40/17 (rear). Is it ok to use 225s in front and 255s in the rear? Are the rims on 04-05 the same width as 06-07? I would hate to create another issue...
