S2000 water leaks
Old Jul 16, 2003 | 07:47 AM
mcmahonplus1's Avatar
Default S2000 water leaks
Hello!!!
I just purchased a 2000 black S2000. The car is more than I expected. What a rush!!
I do have a question related to the air conditioner. Does anyone have a problem with water dripping under the passanger side dash board. I called the dealership and was told the overflow tub may be plugged. That doesn't seem correct since the overflow tube is still allowing the car to release water underneather the front of the vehicle.
Anyone have an idea!
Michael
Old Jul 16, 2003 | 08:08 AM
Kenny_Stang's Avatar
I think you're looking for the "Leaky Air Conditioner TSB" which is TSB83. Check the Library link above for more info.
Old Jul 16, 2003 | 08:22 AM
pjkwong's Avatar
It could be partially clogged.
That has happened to me in other cars before.
I noticed it when my carpets were all wet.
After they open up the tube water leaked out for a hour.
Old Jul 16, 2003 | 08:27 AM
wanabe's Avatar
should be a simple dealer fix item...
Old Jul 16, 2003 | 08:52 AM
cdelena's Avatar
I don't think it is all that simple.. most of the time I don't think it a clog, but the fact that the unit sweats in high humidity.. I don't think you can control it during top down operation. I have found no fix for mine.
Here is the TSB comments from the library..
TSB 083, Leaky Air Conditioner
Service Bulletin Number: 00083
Bulletin Sequence Number: 199
Date of Bulletin: 0010
NHTSA Item Number: SB619954
Make: HONDA
Model: S2000
Year: 2000
Component: AIR CONDITIONER
Summary: THIS BULLETIN STATES THAT IN HUMID CONDITIONS, WITH THE A/C ON AND THE FAN RUNNING AT MAXIMUM SPEED, WATER DRIPS ON THE PASSENGER'S CARPET. *TT
When the AC is on maximum in humid conditions, condensation builds up on the condenser. The fan (on max) blows the water into the heater box which isn't water tight. The water leaks from the heater box into the passenger compartment. The fix is to get Dupont waterproof paste and tape to waterproof the seam of heater box. "vfr800"
It is a big job! You have to remove the evaporator/heater box and then seal a seam in the heater box. It is a shame to have have to remove the evaporator since this means opening the refrigerant lines and creating the necessity of evacuating and recharging. I always am very leery of opening a refrigerant system, especially when it isn't broke. BTW, Honda only allows 2 hours for the technician for this job. Considering the work to recharge the refrigerant I think this is awfully low. "Big Al"
Old Jul 16, 2003 | 08:55 AM
dave22's Avatar
Mine was doing it...got the TSB done and now it doesn't happen anymore
Old Jul 16, 2003 | 03:11 PM
Thanks for all your input!
I will try the suggestions:
Michael
Top_down
Aug 9, 2014 11:34 PM
Dash
May 20, 2014 06:33 PM
scho01
Nov 7, 2008 09:48 AM
MC_BLADE
Jun 27, 2007 03:08 AM
boosted"S"
Jun 18, 2007 06:39 PM
