For S2000s that have been hit in the front
In a nutshell, a woman in a Suburban backed into my front end a few years ago. Here's the summary of events.....
https://www.s2ki.com/forums/index.php?showtopic=318931
Basically, after the repair, the HID cutoff lines are misaligned. You can adjust the vertical heights of the lines with a long screwdriver, but I don't think you can adjust the beams in any other way. My problem is that both of my cutoff lines aren't even straight (parallel to the ground) to begin with, but are curved like "frowns". Here's my post at HIDplanet.com - I'm still waiting on responses.....
http://www.hidplanet.com/forums/viewtopic.php?t=19595
Has anyone had their front end repaired and the HID lights never looked the same? Here are some pics.....
TIA.
TIA.
It's supposed to be lower and dimmer on the left hand side. It's also supposed to have that dip in the middle. As you probably know...
The frown doesn't look right, but it could be the lot. Which isn't 100% level. Any other pictures in the gallery?
Also in the first picture, it doesn't look like the dip from the left headlight lines up with the dip from the right. Maybe if the dip was centered and in the middle the frown would go away. Have you considered going to the dealer, to get them adjusted to spec? $$$
Originally Posted by __redruM,Mar 1 2008, 08:54 PM
