Sanding headlight assembly
Old Nov 2, 2003 | 11:13 AM
silvs2knvb's Avatar
Default Sanding headlight assembly
My car has 31K miles on it and I am starting to take notice of all the little chips in the headlights so what im wondering is has anyone sanded them down a little to make them appear more clear. Any input on sandpaper used and and other information will be appreciated.
Jeremiah
Old Nov 2, 2003 | 11:26 AM
DouglaS2000's Avatar
FYI, sanding any clear plastic lense such as the one on our headlights will leave permanent damage in the form of a haze. It may work on real glass but it will not work under any circumstances for plastic.
Old Nov 2, 2003 | 11:29 AM
amongmany's Avatar
I've done this. I used 1500 grit sand paper and did it very lightly. You have to go over it with plexus afterwards. It takes a lot of polishing and a lot of elbow grease, but it works.
I noticed a VERY SLIGHT hazing in a few areas, but it doesn't affect the light at all and realy isn't noticable unless you look very closely and catch the right light.
Old Nov 2, 2003 | 11:41 AM
silvs2knvb's Avatar
Thanks for the tips guys i appreciate it.
Old Nov 2, 2003 | 02:35 PM
Road Rage's Avatar
I have seen professional kits for clearing pitted glass, which consists of various stages of abrasives (high cut to low cut) and then polishing with jeweler's rouge - I guess the same could be done for plastic, but this should be done by a pro or someone with experience. I would find out what kind of material the headlight cover uses (polycarbonate?) and then get a sheet of it and practice. Search on windshield re-finishing or similar on Google.
Old Nov 3, 2003 | 05:33 AM
cashout's Avatar
Plain old swirl remover (the one you'd use on your car's paint) will remove most of the little dots with a 10 minute strong rubbing pass.
The big ones may take more drastic measures like sanding but I wouldn't use anything less than a 2000 grit wet sand paper. Then do the swirl remover thing.
Old Nov 3, 2003 | 09:21 AM
gomason's Avatar
WAIT- YOU NEED NOTHING OTHER THAN POLISH'S #2 and #1 from this link. I had the same problem, with hazing, and this stuff worked amazing. #3 is not for polycarbonate, so don't use that. Start off with #2 and then work it for 10 min. 10 more min with #1 and you're done- lights look brand new, and for 9 bucks too!
http://www.aircraftspruce.com/catalog/cspa...vusproducts.php
Old Nov 3, 2003 | 09:41 AM
EVAN_In_A_SPA's Avatar
[QUOTE]Originally posted by gomason
Old Nov 3, 2003 | 07:43 PM
HankookS2K
Sep 26, 2013 09:37 AM
Atb117
Sep 21, 2008 08:58 AM
rugsr
Apr 3, 2007 11:44 AM
juice04
Mar 29, 2006 02:49 PM
WalkingDrunken
May 21, 2005 05:32 PM
