Serious Engine Problem...HELP!!
I'm sorry to hear that some other members of this board have hesitation problems as well. Even if the problem occurs when the engine is cold, that is too often.
Unforetunitely, my hesitation occurs when the car is cold, warm, or hot...At this point my TR6 drives smoother than my S2000, this is rediculous!!
Nahh, You didnt get my problem, It was only after I modified the engine with the FPR and even then its only SLIGHT you can barley tell, and only if you drove it all the time.
So my point was, No problems with mine, so theirs should be unacceptable!
Originally posted by PJ2K:
I had a stalling problem that the dealer couldn't find. But I found that the problem was that the MAP sensor was coming loose and just needed re-seating. So check the sensors to see if there coming loose.
