Shift boot Stopper/lock
Old Jan 27, 2003 | 08:47 AM
Blue Bitch 2K's Avatar
Default Shift boot Stopper/lock
I just changed the shift knob on my car and for some reason the piece that holds the boot tight to the shifter is vibrating and the boot will not stay up high enough to cover the whole shifter. How do I adjust/fix this. It is driving me nutz. Thanks.
Old Jan 27, 2003 | 09:33 AM
Asura's Avatar
Take the console off. You will find that there is a zip tie that is doing this job. You can remove it an install a smaller one and make it tighter. Be careful not to make it too tight.
Old Jan 27, 2003 | 10:14 AM
I have to take the whole console off?????? How do i do that without damaging anything?
Old Jan 27, 2003 | 11:29 AM
Uncle Fester's Avatar
The whole console is actually held in with push in clips. Should just pull right off. Just be careful because you have wires going to your hazard lights switch (and maybe a rear window defroster, depending on your model year.) Just be sure to pull up carefully, and then disconnect those electrical connectors and the whole console will come off! HTH.
Old Jan 27, 2003 | 11:43 AM
Muz's Avatar
Muz
Former Sponsor
If you're going to go to that trouble you may as well replace your shift boot at the same time with a genuine leather one which will be stiffer.
xoz
May 12, 2014 08:50 PM
roflitzjinno
Oct 1, 2008 12:00 PM
glne2
Feb 20, 2005 08:04 PM
svann
Jan 12, 2002 04:06 PM
