Shift knob shakes... Is this normal?
Old Oct 18, 2004 | 04:26 PM
mikegarrison's Avatar
Originally Posted by Flood5,Oct 18 2004, 05:18 PM
I'd imagine it doesn't unsettle the car as much when you get on/off the throttle when entering/exiting the corners.
If you do that correctly, it doesn't unsettle the car at all.
Old Oct 18, 2004 | 05:59 PM
TunedS2000's Avatar
Thanks for the help.
Old Oct 18, 2004 | 06:32 PM
vAnt's Avatar
in addition you should never rest your hand on the shift knob. only when shifting. you'll wear out parts by not allowing the motion of the ocean
WTH!!! I didn't know that!!! Crap ;p
Old Oct 18, 2004 | 06:49 PM
This statement is wrong and right at the same time.
You aren't going to "wear out parts" by resting your hand on the shifter. I suppose there might be a tiny bit more wear on the bushings, but it's not likely to make any difference.
But resting your hand on the shifter is a stupid and dangerous habit. Your hands should be on the wheel, not on the shifter. Unless you are actually shifting at that moment, of course.
Old Oct 18, 2004 | 07:41 PM
WPS's Avatar
WPS
well there is wear going on. when you rest your hand on the shifter, you are loading a transmission component (called a slider) against components, either the blocking ring or the gear stop. This will cause accelerated wear on the softer-metalled blocking ring, which will soon lend itself to popping out of gear. It can also cause an overheated gear from the additional loading. This will not show itself until fatigue breaks it.
Old Oct 18, 2004 | 07:53 PM
Well, I won't fight you over it. Especially since either way, the result is the same. Drivers should not keep their hand on the shifter. Or anywhere other than 9-3 on the wheel, really. No matter how cuddly the passenger is....
Old Oct 18, 2004 | 09:18 PM
MaxGeek's Avatar
There are exceptions to every rule.
Old Oct 18, 2004 | 09:22 PM
Kodokan_4's Avatar
Originally Posted by Flood5,Oct 18 2004, 03:51 PM
Pete, where can one get those, and how hard are they to install?
What about stiffer (urethane) tranny mounts? Does anyone make those?
The engine damper is made by J's racing and is available from retailers who carry their products. The installation is not complicated and takes about an hour.
Spoon makes competition engine and tranny mounts:
-Pete
Old Oct 18, 2004 | 09:44 PM
RazorV3's Avatar
[QUOTE=WPS,Oct 19 2004, 04:41 AM] well there is wear going on.
Old Oct 18, 2004 | 09:53 PM
vAnt's Avatar
How do you look smooth while shifting if you can't keep your hand on the knob? ;p
Just curious ;p
