Shifting to 1st from dead stop on hill
Old May 18, 2001 | 10:55 PM
Jay Li's Avatar
I just use the basic rev the engine to 2k, and bring the clutch just to the point where it's about to catch, and I'm fine. Took a couple tries to get down, now it's like nothing.
Old May 18, 2001 | 11:00 PM
reecespieces's Avatar
I did the same thing Jay did when I was learning. I revved to 2k and let the clutch out until it catches then everything is 'downhill' so to speak
Now I can do it without revving first
Practice on a nice grade a few times...you'll get it within an hour!
Old May 19, 2001 | 06:26 AM
WhataRide's Avatar
Originally posted by s2kblk
When I was drving around in SF, I kept my car in gear on the hills. I just balanced the gas and the clutch to keep me stationary. I didn't feel comfortable taking the car out of gear on some of the steeper hills. If you're going to be in neutral while waiting for the light or stop sign, you'll want to let the clutch catch asap. Or else, you'll back up and hit somebody. I would then give it some gas as you slowly release the clutch to get the car moving. Then you can let go of the clutch. I can never understand people who get right on your bumper when you're on a hill. Don't they know that cars may roll back a little before going forward?
Didn't you smell burning clutch?
Old May 19, 2001 | 08:53 AM
s2kblk's Avatar
I kept the clutch half in while giving a little gas, just enough to stay still. No burning clutch though. The only time I smelled a burning clutch was on high RPM clutch drops for high acceleration purposes. However, I am aware that long term side effects of keeping your foot on the clutch can shorten the life of the clutch. Then again, I'm in LA not SF, so I'm not on steep hills that much.
Old May 19, 2001 | 10:18 AM
WhataRide's Avatar
Anytime you're on a hill and use this method to remain stationary, you're shortening the life of your clutch.
Good Luck.
Old May 19, 2001 | 11:31 AM
griffin's Avatar
Im still fairly new to shifting, but heres what I do.
When stopped on hill, its in neutral with normal brake applied.
When its time to go, I push the clutch in shift to 1st, release brake and release clutch fast to "that point" then give it gas and go.
"that point" is where the clutch is engaged enough to not have the car roll backwards, finding that was the key.
Old May 19, 2001 | 03:16 PM
WhataRide's Avatar
Sounds good to me!
Old May 19, 2001 | 03:23 PM
kizneda's Avatar
I consider myself fairly competent with the stick but the hills in San Francisco can still induce panic - especially when the considerate driver behind you gives you all of two inches leeway.
Old May 19, 2001 | 03:34 PM
WhataRide's Avatar
I've also driven the hills of San Francisco, they're in a class by themselves.
Old May 19, 2001 | 11:27 PM
WoofWoof's Avatar
Actually finding "that point" is easy... put your car in gear and slow~~~~ly let off your clutch. Watch your RPM - the RPM will dip a little bit when the clutch catches. That is the "point!!!"
This is how I learned how to drive stick in those damn hills in SF.
_meh
Feb 19, 2013 11:41 AM
acn684
May 15, 2012 07:00 AM
jaehoppa
May 20, 2007 10:47 AM
nivag
Apr 24, 2006 12:01 PM
emrillive
Jan 20, 2004 12:19 AM
