Is shifting diagonally to 5th bad?
Old Dec 13, 2005 | 11:31 PM
hpark's Avatar
what the???? even if you shift diagonally isn't it still going through the H gate??? i'm confused.
Old Dec 14, 2005 | 03:29 AM
vbb's Avatar
vbb
There is no harm to the car in directly shifting from 4th to 5th gear. I know exactly what you are talking about. One way (the slow way) to shift to 5th is to sort of return the shifter to the middle, then move it over to the right and then up into 5th. It's kind of a 3 step motion. That's definitely a way to do it, but it is incredibly slow. The other way to shift from 4th to 5th is to kind press up and to the right at the same time, ie: shifting diagonally. It makes the 4-5 shift as quick as all of the others, and it's the way I do it.
As long as you are jamming the thing into gear, you're fine. It should naturally slide into 5th from 4th the same as in all other gears. If there is one thing that the S2K has that's nicer than almost any car out there, it's shifter feel.
Old Dec 14, 2005 | 01:13 PM
dat s2k's Avatar
its basically like shifting from 2nd to 3rd except your adding the slight sideways froce. and ive been told(and always have done) to push STRAIGHT up going from 2nd to 3rd and not do a 3 step motion.
Old Dec 14, 2005 | 02:18 PM
Honda 367's Avatar
Actually, I always shifted in H pattern but it is good to know that you can shift diagonally though I will stick with the way I have been doing for the past 27 years.
Old Dec 14, 2005 | 02:37 PM
sjs2k4o8's Avatar
Where do you think of questions like this?
If you had a guide on the shifter it would be on top like the Ferrari's
xproteK
Sep 10, 2014 07:08 PM
Frez2k
Jul 29, 2010 07:11 PM
jakub2000
Nov 26, 2005 09:48 AM
S2kracka
May 1, 2005 06:52 PM
