Shifting gear 2nd to 3rd
Old Oct 2, 2008 | 03:57 PM
tntrac's Avatar
Default Shifting gear 2nd to 3rd
Guys,
I have owned the s2000 for a little over a month now.
What I noticed is when I shift from 2nd gear to 3rd gear (without a pause, one motion), going into gear is not perfect. The smoothness is not there.
But if I leave it in netural for a split second, then go to 3rd gear, it feels more clean and natural.
Any thoughts?
Btw, it is an 07 with 9k miles.
Tony
Old Oct 2, 2008 | 05:05 PM
G's Avatar
G
it is probably the combo of the clutch delay valve and the VSA. Does it happen if you have the VSA turned off?
Old Oct 2, 2008 | 05:16 PM
AP2Berlina's Avatar
happens to me too..06 with 5700 miles...notchy from 1-2 2-3 but goes away after a while of driving and after it is fully warm..but yeah i know what your saying...stop in neutral and it feels fine going in
i don't think it is a problem considering it goes away for me after a while and then the tranny is smooth like butter
how long do you take your car out for a time..maybe the tranny is not completely warmed up although the engine is...
Old Oct 2, 2008 | 05:18 PM
deathsled's Avatar
VSA affecting shift quality?
Old Oct 2, 2008 | 05:42 PM
Saki GT's Avatar
Well, its probably the windshield wipers and radio volume actually....
Seriously though, VSA is stability control - not part of the shifting action. The CDV is in the clutch hydraulics, but only manages engagement speed to limit shock.
The S2k shifter is notchy - its a direct link, and until the car's transmission is hot, you will get notchiness, so that's normal. Its also a short shifter, so maybe you're just shifting too quickly - about how many seconds would you say it takes you to shift from 2 to 3?
Old Oct 2, 2008 | 06:32 PM
RedY2KS2k's Avatar
Yeah, that's a good one.
Old Oct 2, 2008 | 06:35 PM
s2k>wrx's Avatar
takes me about .0000132 of a sec lol
Old Oct 2, 2008 | 07:00 PM
haywoodjablome's Avatar
How long does it take to learn how to drive stick properly? Shifting from one gear to another, up or down, whether it takes 1/4 sec, 1 sec, 5 secs, can be done smoothly. It's a matter of driver technique.
Old Oct 2, 2008 | 07:25 PM
duanet85's Avatar
search for what kind of grease to use for the shifter and put a little more down there. i put some grease on my axialflow ss and installed it and had to pull it again and add more grease to get rid of the notchieness
Old Oct 2, 2008 | 08:18 PM
roflitzjinno's Avatar
try changing the tranny fluid? it could possibly help?
