Shin-Etsu silicone grease
Old Mar 17, 2008 | 07:11 PM
GT_NFR's Avatar
Originally Posted by Mrfixit687,Mar 17 2008, 02:04 PM
why dont u just get the real deal? its not like its very expensive
There is nothing "real deal" about it, why would I drive 60 miles back and forth to a dealership just to get a tube of "JDM" grease? Silicone grease is silicone grease nothing more to it.
Old Mar 17, 2008 | 09:20 PM
Dan H's Avatar
Or have it shipped to your door along with other maintenance parts.
Old Mar 18, 2008 | 07:58 AM
Hockey's Avatar
[QUOTE=Choungsgay,Mar 17 2008, 07:11 PM] There is nothing "real deal" about it, why would I drive 60 miles back and forth to a dealership just to get a tube of "JDM" grease?
Old Mar 18, 2008 | 08:29 AM
GT_NFR's Avatar
I had just cleaned my car that day and decided on a whim to apply silicone grease and the silicone grease from autozone was simply the most readily available. If you are so set on shin-etsu grease could you possibly detail the chemical make-up of the shin-etsu silicone grease vs my autozone silicone grease and exactly what compound makes it so much better?
Old Mar 18, 2008 | 08:53 AM
Alexis's Avatar
Thanks for the input. I appreciate it. It looks like Shin-Etsu silicone grease is not that much different from other silicone greases. If I get the Honda stuff, so much the better, if not, so be it, just about any silicone grease will do.
Old Mar 18, 2008 | 08:54 AM
Alexis's Avatar
Originally Posted by shotiable,Mar 17 2008, 02:54 PM
dude... do you guys have a picture of where you're supposed to grease up the soft top articulations? i would like to start doing this as well because i frequently go top down... i could imagine how much wear and tear i put on my whole convertible mechanism
Oddly enough, the Owner
Old Mar 18, 2008 | 08:59 AM
Alexis's Avatar
For whatever it's worth:
Lubricating Greases & Dielectric Compounds
Silicone grease consists of silicone fluid, thickened with metallic soap and other additives. Silicone compound is a grease-like silicone fluid that has been thickened with fine particles of silica. Both offer excellent heat and oxidation stability, as well as electrical properties and water repellency. Silicone greases and fluid compounds are ideal for electrical insulation, sealing, radiant heating and applications requiring water repellency. Primarily used in transportation, electrical/electronics and machine tooling industries, these products highly stable, reliable, and inert.
http://www.silicone.jp/e/co-operate/guide/oil.html
Characteristics of Silicone Grease
Silicone grease products are made with a silicone fluid base oil blended with materials such as fillers, oiliness improvers and antioxidants. They have greater thermo-oxidative stability and moisture resistance than common mineral oil-based greases, and can be used in a wider range of temperatures. Furthermore, silicone greases are chemically inert, so they can be used on almost any equipment.
http://www.chilternconnections.co.uk/Shin-...properties.html
Old Mar 18, 2008 | 02:38 PM
MitsukillinS2K's Avatar
id just get Shin-etsu. Its like 5 bucks from HTG.
Old Mar 18, 2008 | 05:21 PM
kstokes's Avatar
I just use dielectric silicone grease. It's very common, highly available, can be had for very little money, and you can use it on your battery terminals to keep them from corroding (keeping oxygen away from things is what it is designed to do...).
Old Mar 18, 2008 | 06:17 PM
jkoup71's Avatar
went to the dealer to show the squickiness of the top and the mechanic who took a ride with me gave me a full tube of shin-etsu
