Short Block
Old Mar 15, 2007 | 06:05 AM
mknightx's Avatar
Default Short Block
Does the short block from Majestic Honda come with the pistons,crank and everything needed just for a swap with an existing block or is it empty and will need everything installed into it?
Link.
It looks like it comes with everything.
Old Mar 15, 2007 | 06:10 AM
Stratocaster's Avatar
It is a built short block. Just bolt on the head and everything that bolts to the outside and drive.
Old Mar 15, 2007 | 06:18 AM
Sideways's Avatar
Get a motor rebuild gasket set while you are there.
milkbubble's Avatar
Wow not bad for the short block!
Old Mar 15, 2007 | 06:25 AM
mknightx's Avatar
Is it better for me to find a replacement engine (had a scored #4 clyinder) or replace the short block. Seems like replacing the short block involves a lot more labor. Since a shop will be doing this for me trying to find the easiest route and most cost effective route.
Also, these short blocks should have the new banjo bolts right?
Thanks
Old Mar 15, 2007 | 06:37 AM
Used engine could mean someone elses problem. Perfect motors don't just drop from the sky, do they? Something happened to the car.
The short block is the way to go. The amount of labor to install a short block or motor is the same give or take. It is just the way the car is put together.
Once you install a short block, the car is as good as new.
Yes, they should. They updated this back in 02
Old Mar 15, 2007 | 06:46 AM
Sideways's Avatar
Perfect time to get a f22c bottom end.
Old Mar 15, 2007 | 07:15 AM
They want another 1K for that short block. I passed the last time I needed one.
Old Mar 15, 2007 | 07:27 AM
mknightx's Avatar
Which set is it? I found one that says: GASKET KIT, CYLINDER HEAD and GASKET KIT, CYLINDER BLOCK.
Is this what i need?
Old Mar 15, 2007 | 07:34 AM
Sideways's Avatar
Get both.
