Short shifter...
Old Sep 2, 2006 | 01:12 PM
dean's Avatar
Originally Posted by Nate03,Aug 24 2006, 02:40 PM
there are several LHD - C's 'Style' shifters on eBay for less than 100 dollars....
I have removed the RP shifter from my ride due to rattle/buzz that I could not correct - trying all fixes and adjustments...
...and installed the C's Style received from an eBay vendor. This shifter has proper hard rubber insulation; has an actual raising of the shift fulcrum point (versus only a shortening of the shifter length); is rattle & buzz free; feels as solid as OEM...with the height of the knob being lower than OEM and slightly taller than the RP model.
by heating the OEM plastic parts that I purchased separately (I think for 7 dollars) rather than removing from my OEM shifter (which is an option) - they easily attach to the C's Style shifter... using the OEM plastic seems to assure a smooth movement of the shifter once installed ...
I'm very pleased witht the shifter I purchased off of eBay.
YMMV
I had to remove my RP shifter because of the noise as well. How is the C's style working out for you now that you've had it a while? Also, do you happen to have the part numbers for the OEM pieces you bought? I think that I may follow your lead and give the C's style a try.
Old Sep 2, 2006 | 01:27 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Get the "Real McCoy";Richard Pauk SS,from Rick's.
S2000Shifter
Jan 2, 2021 06:42 PM
trails
Nov 14, 2015 01:58 AM
datbird
Aug 18, 2009 04:49 PM
Bassoctopus
Car Talk - Non S2000
Mar 25, 2007 02:39 AM
mwinner
Aug 15, 2004 02:32 PM
