skid pad
Old Sep 11, 2005 | 02:54 PM
jdo009's Avatar
Default skid pad
how many g's does a stock s2k pull on the skid pad
also whats your set up and what kind of g's are you pulling
Old Sep 11, 2005 | 05:28 PM
WVtwisties's Avatar
looks like no one is paying attention to this topic!!!
I'm sure you can look that stock figure up but all I have to say is probably very very few S owners have had their car on a skid pad.
Old Sep 11, 2005 | 06:57 PM
Fongu's Avatar
The skidpad number is mostly determined by the stickiness of the tires. Get really wide R-compounds or racing slicks and you'll be pulling big time G's. To a lesser extent, the front and rear balance of roll stiffness combined with camber settings and lower center of gravity effect skidpad numbers.
Anyways, it is only a single performance measurement (lateral grip at constant throttle) and in the whole scheme of things just as unimportant as something like a 0-60 time. Nice to know, but not the end all, be all, and definitely not a total measure of handling. It's better to have whatever setup that gives the particular driver confidence in the car, and that is different for everybody.
That being said, a stock S2000 exhibits mild-understeer on a skidpad. Theoretically you should try to increase front end grip, but most people complain about horrible oversteer (mainly bad control of throttle controlled oversteer) and changing the static balance to improve the skidpad would result in most people unanble to control a typical real-world high speed turn.
Old Sep 11, 2005 | 07:08 PM
switchcars's Avatar
I seem to remember seeing numbers for the AP1 and it pulled 0.81g on the skidpad.
Old Sep 11, 2005 | 08:00 PM
Ludedude's Avatar
Administrator
That would be 0.91 G for an AP1 chassis on OEM rubber.
Old Sep 12, 2005 | 08:51 AM
Wisconsin S2k's Avatar
S2000 holds the highest (at least it did at one point) record for g's on a skidpad for modified factory production vehicle.
the Spoon S2000 did 1.17g's.
Old Sep 12, 2005 | 09:19 AM
brent_strong's Avatar
Another thing to remember is, like was mentioned before, the skidpad tells you very little about handling capability, just about maximum lateral grip. Polar moment of inertia and other such things aren't taken into account at all. IIRC, the best setup on a skidpad is a horribly simple chassis, a twin I-beam style. Obviously it doesn't follow that this is the best chassis for hanlding.
Just something to keep in mind.
Old Sep 12, 2005 | 09:22 AM
mrmophandle's Avatar
Once I got used to the handling, I didn't need skidpads anymore. I still keep a set of Depends in the trunk just in case I find a good road though...
Old Sep 12, 2005 | 10:44 AM
WVtwisties's Avatar
LIFE'S A SKIDPAD!
Old Sep 12, 2005 | 11:17 AM
switchcars's Avatar
oops....either my bad memory or a misprint from my source....I'm betting the first.
