slipping the clutch
Old Dec 22, 2005 | 12:16 AM
JLEEzAP2's Avatar
Default slipping the clutch
Well I understand everything about launches.. under certain circumstances you have to adjust the rpm point but it should always be pretty high.. i know i have to remove my clutch delay to do a launch without breaking something. But everyone is always saying "slip" the clutch... what does slippping the clutch mean? Is it different from side stepping or dropping the clutch?
Thanks
Old Dec 22, 2005 | 06:14 AM
xviper's Avatar
You "slip" the clutch every time you take off normally.
Old Dec 22, 2005 | 07:10 AM
Conedodger's Avatar
Actually, the delay valve is there to help prevent breaking stuff. Removing it will make it easier to break things.
Old Dec 22, 2005 | 07:52 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Don't do it.!!! Don't slip the clutch,DUMP it.!!
And modulate your traction,with the GO pedal.!!!
Old Dec 22, 2005 | 08:22 AM
Mikes256's Avatar
Is that the one on the right or the left ??!
Old Dec 22, 2005 | 08:25 AM
Try the one in the middle.!!!
Old Dec 22, 2005 | 08:55 AM
xviper's Avatar
Are you sure? Well, maybe you DON'T!
If you understood "everything" about launches, you would know the answers to the following:
Old Dec 22, 2005 | 09:11 AM
vojm17's Avatar
jeez tough crowd
Old Dec 22, 2005 | 09:14 AM
xviper's Avatar
Originally Posted by vojm17,Dec 22 2005, 12:11 PM
jeez tough crowd
Moral of this story ..........................................
If you state you know "everything" about a subject and then promptly ask questions about that subject, you just painted a large BULLSEYE on your forehead.
Old Dec 22, 2005 | 09:21 AM
DrCloud's Avatar
[Don't mind xviper. He ran out of regular coffee this morning and had to resort to decaf, so he's less patient than he usually is. Also less focused -- with caffeine, he would have caught that gaffe on his first response.]
HPH
