Sluggish in low gear or RPM's
Old Feb 13, 2004 | 08:52 AM
s2k4's Avatar
Anyone of you guys experienced some kind slowness in the lower speeds or RPM's... MY04 is what I have...Oil check good ..less than 2500 miles. It's almost like it seems a bit slow, then it picks up good once you get moving at higher speeds.
Old Feb 13, 2004 | 08:58 AM
sebrings2k's Avatar
The main reason you want to keep the engine revving
Old Feb 13, 2004 | 09:23 AM
cyber_x's Avatar
s2k4,
Are you sure it's not just the low torque? The S2000 is pretty wimpy off the line and you need to keep the revs high to go fast.
Ace10's Avatar
is this some sort of trick question?
Old Feb 13, 2004 | 09:54 AM
s2k4's Avatar
Funny, Fellas...! No, maybe it's just my imagination...or I am just getting used to my S ...it just seems a bit more sluggish than normal.
Old Feb 13, 2004 | 10:35 AM
xviper's Avatar
Could be your clutch/throttle technique. Go for a ride with someone else or have someone else ride with you to see what they say.
Old Feb 13, 2004 | 11:55 AM
OverBooster's Avatar
What everyone means to tell you is that the S2000's are VERY weak when it comes to low end torque. My last car was an 02 WRX and I really miss that low end torque. The car is a high revving beast meant to shine in the high rpm range. In short, keep the car at higher rpm's and never fear that when VTEC comes all your troubles are over. What you are experiencing is normal.
Ryan
BuellRunner
Jun 5, 2014 08:05 AM
Syn
Mar 17, 2013 11:48 AM
dolebludger
Aug 3, 2007 09:24 AM
chuhsi
Dec 1, 2006 09:02 PM
