SO2 question-need help ASAP!
Old Jan 31, 2001 | 09:51 AM
Barry's Avatar
Hi,
Getting exhaust put on today at Weseloh Honda....at the same time wanted to put new rear tires on.
What they have in stock is a 225/50-16 SO2, 140 tread wear which they say is the OEM tire.
How do I know for sure? Are there any other identifiable markings?
The guy says they match up exactly to what is currently on my car and a new one on the floor....
Thanks for the help!
Barry
Old Jan 31, 2001 | 09:57 AM
pellisS2k's Avatar
If your car is there, why not take one of the tires out and compare?
Otherwise, I believe the the only W-rated S-02 in 225/50/16 is the OEM one.
How much are they asking for the tire and can they get more?
Old Jan 31, 2001 | 09:58 AM
STL's Avatar
STL
Try using the SEARCH function...
Old Jan 31, 2001 | 10:00 AM
Barry's Avatar
He did compare and says they look the same.....I guess I want to know how do you REALLY know if its the same.
Maybe they are!
Don't know price yet, havent gotten to that.
Thanks for replying
Old Jan 31, 2001 | 10:13 AM
VA S2K's Avatar
The tires should have the same tread pattern, exact same contact patches, same size grooves in the tread, etc. The S-02 PP and S-02 Z-rated have similar tread patterns but wider grooves and smaller contact patches (better wet, not as good dry).
Old Jan 31, 2001 | 10:28 AM
Mikey's Avatar
If you do a search you'll find extensive information on the tire specs. Or you can check the faq on s2ki
https://www.s2ki.com/faqs/faq_tires.php
Old Jan 31, 2001 | 10:35 AM
Swurvydel's Avatar
if you're buying these from the dealer you can get them much cheaper through tire rack....significantly cheaper...check it out first
Old Jan 31, 2001 | 10:45 AM
Barry's Avatar
thanks for the responses...
i did a search (should have done that first) and then called Conner at TireRack.
The identifier is "92W load rating"...
Now confirming this is what the dealer has and getting pricing.
Mountain Man
Mar 24, 2015 06:28 PM
j03chu
Mar 8, 2006 03:01 PM
BMF
Dec 21, 2002 05:00 PM
millenniumRX2
Dec 6, 2001 12:16 PM
