soft top boot
Old Sep 27, 2001 | 04:16 PM
J MAN's Avatar
Default soft top boot
Does anyone know how to make this excuse for a boot stay locked in the back groove? Anyother opinions on this welcome.
Old Sep 27, 2001 | 05:16 PM
Takashi KazuMori's Avatar
Don't understand what you mean, can you be more specific?
Old Sep 27, 2001 | 06:21 PM
VTEXTC's Avatar
I think what is meant here is that upon driving the vehicle, the rear tabs on the boot pop out, hence making the rear of the boot stick up in the air an inch or two.
To answer the question, I think that there was already a thread posted a while ago. Answers revolved around adjusting the top mechanism so that the soft top sits lower in the well when retracted. Again, I can't be too sure, but a search may help somewhat.
Asif
Old Sep 27, 2001 | 09:36 PM
tmkarab's Avatar
Yes, i just got mine adjusted - look in the library for the TSB - it's worth it in my opinion to get this fixed...
Old Sep 28, 2001 | 10:23 AM
PLYRS 3's Avatar
it's happening because your top sits too high when in the "open" position.
it should sit flush with the top of the trunk when open/retracted - have it adjusted and it will eliminate your problem.
i believe there is a TSB specifically for it - although mine was done during the seat belt TSB.
if the dealer does it REALLY right, you won't even need the boot because the top won't even be visible from behind (people driving behind you won't see the edges sticking up/out)
mine disappears nicely
Old Sep 28, 2001 | 10:54 AM
txst's Avatar
It is TSB 01-038. I found that there was a TSB on this issue and had my dealer fax me a copy of it, then performed the work myself (The more I talk with dealers, the more I realize how incompetent they are when it comes to this car). The cover now stays put.
Old Sep 28, 2001 | 11:11 AM
wanabe's Avatar
you do not indicate which year your car is... if one of the first built, the boot was recalled (and you should get the new one). if a new one then ignore this post.
Old Sep 28, 2001 | 12:42 PM
J MAN's Avatar
My S is a 2001 and thanks for the info. Just bought the car so I wasen't aware of the previous posts. Thanks for the info.
Old May 11, 2003 | 10:46 PM
antek's Avatar
[QUOTE]Originally posted by txst
[B]It is TSB 01-038.
Old May 12, 2003 | 04:13 AM
Austblue's Avatar
Originally posted by antek
@txst,
would it be possible for you to either scan or fax this TSB and send it to me?
thx!
[QUOTE]Originally posted by tmkarab
[B]Yes, i just got mine adjusted - look in the library for the TSB - it's worth it in my opinion to get this fixed
