Soft top replacement help
I'm trying to install a new soft top on my 01. I bought the EZ top with the glass upgrade, from topsonline.com. I'm stuck on the part with attaching the new top on the side frame rails. I read the step by step instructions and I'm still lost. I also need help with the tension strap, I can't figure out where it goes.
Any help would be appreciated.
Sent from my HTC6435LVW using Tapatalk 2
I also installed an EZ-On glass top in my 2005 back in January. I actually made the mistake of riveting that tension cable without slipping it into the fabric "tunnels" on either side of the soft top. Looked like crap, and I had to fix it.
Like I said, you can see there's a cloth tunnel on either side which is made long enough to hide that tension cable from where it rivets in the front to where it screws in the back. I ended up buying a long thing screw retriever thing (i suck at car terminology) that is used to pull out dropped screws in your engine bay, etc. I fed the retriever through the tunnel, grabbed the spring, and pulled it through the narrow tunnel, then screwed the spring part, and riveted the front part in place.
mrxjeffrey
Jun 27, 2011 10:07 PM
