Soft top tear fix
Mods,
If this is not the correct forum please move it. This is one of the most detailed fixes I have found. I will be attempting it tonight, so I will post results soon! Wish me luck!
http://www.zjstech.net/SpyderTop/repair.htm
I did that fix using a vinyl repair kit. I even found a close grain pattern that made the repair nearly invisible. It worked ok for about 1 month - but after I raised and lowered the top a few times the repair started to fall apart. The vinyl repair glue doesn't hold up well to being stretched and folded when the top goes down.
I tried all kinds of different glues and tapes but they all fail after the top is lowered a few times. I ended up buying black elastic waistband material (so the material will stretch) and I waterproofed it with Tear-aid, then I sewed it on over the hole. It's permanently fixed now, that patch isn't going anywhere (I sewed it by hand and I made sure to use close, tight stitches).
Originally Posted by chrisjgiuliano,Nov 4 2009, 03:08 PM
Where did you find the waistband material?
http://www.nancysnotions.com/product/suppl...Arrivals&page=1
I was planning to bite the bullet and spend the $1500 to have a new Robbins top installed before winter but this saved me. Total spent was about $15 including the Tear-aid and shipping/handling (I already had the needle and thread!).
Unfortunately I had already spent about $50 trying out different glues and tapes.
Results:
SHITTY!
Was not flexible enough and busted open as soon as I put the top down. (I let it cure for 48 Hours.)
NotSure, if it would not be too much trouble, would you post a pic in this thread of what your repair looks like, as I think that may be my final option. (I am not spending $1,800 to put a new top on an 8 year old car!)
Thanks!
SHITTY!
Thanks!
