Some rev-matching questions
I agree with Jfusion:
My personal opinion with respect to downshifting as you approach stop signs and stop lights etc... , is that it is cheaper to replace brake pads than it is to repair a tranny and clutch. I am one of those guys who lets off the gas as I approach a slow down condition, then put it in neutral as I coast to a stop. I don't downshift approaching a stop unless I expect to re-accelerate before I arrive at a complete stop. Just my thoughts. hth.
That's how I have driven for ~ 40 years. I've never had clutch or MT troubles. Brakes are SO much cheaper and more effective at slowing the car.
Also, if not DC'ing, I let the car show me how quickly I should shift. Hold the shift knob with fingertips, press clutch, gently apply shift pressure, at a point the shifter will smoothly engage the next gear. I notice on my AP2 (heavy flywheel) that a smooth 1-2 requires a fairly slow shift, even when the trans fluid is warm.
I clutch in, shift to second and then wait for the revs to drop to a point I estimate 2nd gear wants and then let the clutch out. I guess this is upshift rev-matching--instead of blipping, you time when to let the clutch out. If I try be quick and slam it, it's jerky as hell.
The 1-2 change is the only upshift I have to consciously rev-match.
Originally Posted by Mark355,Oct 11 2009, 02:09 PM
Yep, I have to shift into second very slowly (probably a full second slower than any other upshift) to have a smooth change. Pretty sure it's because the 1-2 change involves a much larger difference in rpms. Shift too fast and you don't give the engine enough time to drop in revs before second is engaged and it bucks.
This is a little off topic but relevant to the coasting technique. A very knowledgeable poster on another forum commented on coasting to a stop:
http://forums.s2kca.com/showthread.php?t=27347
I haven't had problems coasting to a complete stop although I usually on do it the last 50 - 75 feet.
Originally Posted by ikeyballz,Oct 10 2009, 08:24 PM
exactly!
I read through thsoe threads as well, so half of my information comes from them.
Id assume the clutch wear is not what you should be concerned about. A small jerk just means the clutch si grabbing. You'd do much more damage to the clutch by slipping it excessively on startup. I doubt much people who drive the s2000 can drive it perfectly without jerking it unless they slip the clutch like crazy on shift ups or they're pro.
I'm more concerned about the effects of it further down the line, like the rear end since thats the weakest point of our cars..
My 2 cents on downshifting through the gears when coming to a normal stop:
Why? The S2000 has excellent brakes and doesn't need engine braking to help you slow down. When I am coming to a stop, I'll sometimes downshift to 4th with rev matching and then just let off the throttle leaving it in gear, letting the RPMs come down to about 2,000 before going into neutral for the stop light. You are essentially burning no fuel when off the throttle and decelerating in 1 gear down to 1500 rpms or so.
When driving aggressively through the curves this changes and I am always rev matching and shifting to keep the engine in the powerband regardless of speed.
wow, I think this is the first time I've opened one of these downshifting/synchro threads and actually found good/accurate information
to just add a lil more good info on the s2k trans, here's this ol post. https://www.s2ki.com/forums/index.php?showt...=0&#entry204419
fwiw, i don't skip gears, ever. i do downshift from whatever gear to 2nd every time i come to a stop (or very nearly ever time). why not just coast and use the brakes? Because that isn't nearly as much fun.
