Someone help please!
Old Jul 6, 2009 | 09:05 AM
Incubus's Avatar
Move your right foot over to the right until it touches the wall. Use it to stabilize your foot as you drive. There may be other factors involved such as excess heat, but I think it can be resolved with updating your driving style.
Old Jul 6, 2009 | 09:20 AM
T111MYO's Avatar
Originally Posted by Siepel,Jul 6 2009, 09:05 AM
Actually, I think it's the very infamous "heat soak" bog. Very common on S2000s. I had it with stock intake as well as PRM intake.
Siepel
PS: What was the aftermarket air intake you had?
It was a BMC carbon air intake.
how did you over-come this??
Thanks Tim
Old Jul 6, 2009 | 09:22 AM
T111MYO's Avatar
Afraid there is nothing wrong with my driving technique, my feet are on the correct pedals at all times.
What do you mean by excess heat...??
Tim
Old Jul 6, 2009 | 10:34 AM
Incubus's Avatar
Tim
Your car may have a tendency to "buck" or lunge as a result of high ambient temperatures.
I'm not saying you don't know how to drive, but this car can cause even a good driver to do this. You need to stabilize your right foot while it's on the throttle pedal. Just try it before you reply that it's not your fault.
Old Jul 6, 2009 | 10:45 AM
Vinsfeld's Avatar
check the oil?
Old Jul 6, 2009 | 11:20 AM
DDonovan's Avatar
Look up "heat soak"..., sounds like that is what you are explaining.
Old Jul 6, 2009 | 11:21 AM
Sinji's Avatar
heat soak, or the famous map sensor problem
Old Jul 6, 2009 | 12:24 PM
T111MYO's Avatar
Originally Posted by Vinsfeld,Jul 6 2009, 10:45 AM
check the oil?
Oil is topped up on regular basis
Tim
Old Jul 6, 2009 | 12:26 PM
T111MYO's Avatar
Would this be detected on a plug in machine which garages have to find out a problem within the car??
Thanks Tim
Old Jul 6, 2009 | 04:01 PM
roadie114's Avatar
Hey Tim,
Do you notice it more with the A/C on? My S (and most Hondas I've driven) tend to idle a little too low for my tastes when taking off, and can cause a little shudder if you don't give it some gas. I usually like the rev's up around 2k or so when taking off, idle is around 600-700 on mine. A/C makes it worse. I've just gotten in a habit of blipping the throttle before taking off. Good luck.
