Sounds silly, but...
Old Oct 10, 2006 | 09:18 PM
S2k-Takara's Avatar
Default Sounds silly, but...
I wanna find gears with a smaller number then 4.10 example 3.9
anyone know where I can aquire these?
Old Oct 10, 2006 | 09:20 PM
jdmgpw04's Avatar
i dont think they would make that on a s...
if they ever do i aint putting that on my s...
one more thing WHY?????????????
Old Oct 10, 2006 | 09:35 PM
S2k-Takara's Avatar
I would like each of my gears to be in vtec longer.
Old Oct 10, 2006 | 09:39 PM
mugenrsx's Avatar
Unless you were boosted and actually needed longer gears, your car would be slower with * > 4.10.
Old Oct 10, 2006 | 09:43 PM
Ustemuf's Avatar
being in vtec longer means you are going slower.
Old Oct 10, 2006 | 09:44 PM
S2k-Takara's Avatar
Sometimes switching in the middle of a corner is tough..I was just going to see if there was a cheap solution like the whole kia gear thing, and give it a try.
Old Oct 10, 2006 | 09:48 PM
NFRs2000NYC's Avatar
He does have a point........it depends on the track....certain tracks might benefit from a very slighly taller gear ratio....however, unless you are using it on that one track, and one track only, its a bad idea.
Old Oct 10, 2006 | 11:21 PM
SweART's Avatar
Well, aside from being i vetc longer in each gerar, which I also find of doubtfull value, it would mean a higher top speed (assuming something is done to boost powerlevel above stock) and lower cruise RPM on the highway.
Now, I have not heard anything about such gears for the stock rear end, but perhaps it would be available for replacement ones (diff-tech?)?
Old Oct 10, 2006 | 11:26 PM
AlX Boi's Avatar
It does make sense for someone who uses the car as a DD n is often on freeways. He might not care much about real performance and more about practicality of the drive (not the car : duh).
Old Oct 10, 2006 | 11:33 PM
S2k-Takara's Avatar
have a link to diff tech?
