Spoon cooling mods
Old Feb 1, 2006 | 09:20 AM
Jakup's Avatar
Originally Posted by Lickermat,Feb 1 2006, 01:26 PM
One of the very first free Mods you can do to the stock hood is to remove the insulation cover on the underside.
This not only reduces the temps under the hood but you introduce an air gap for the engine bay so the air can move in and out.
Costs $0.00 and very effective you will notice a huge difference in the amount of heat that is no longer retained under the hood.
Most noticable are the airbox , strutbar (if you have one) & intake hose as far back as the TB is substantually cooler on a permanent basis
Wow, great idea. This doesn't have any negative effects does it?
Any other free mods to reduce under-hood temperatures?
Old Feb 1, 2006 | 09:26 AM
kayvan_pour's Avatar
Banned
I have never heard of this before... But there has to be a reason the insulation is there... I would be interested in hearing more about this.
Old Feb 1, 2006 | 09:27 AM
RED MX5's Avatar
There is more noise without the insulation cover, but if you take it off carefully, you can always reinstall it if you don't like the change. Personally I like being able to hear the motor and SC better.
Old Feb 1, 2006 | 09:38 AM
Jakup's Avatar
As would I. What I meant by negative effects would be something like the hood fading. How does this allow more air in anyway?
Old Feb 1, 2006 | 10:19 AM
Banned
Yea... Wouldn't this warp the hood because so much heat?
Old Feb 1, 2006 | 10:26 AM
S2kracka's Avatar
The paint will crack/fade a lot faster without that insulation. I've had many friends tell me I'm wrong, but guess what happens a few years down the road when my hood paint is still looking perfect
Old Feb 1, 2006 | 01:04 PM
RED MX5's Avatar
I haven't had mine removed long enough to be sure, but so far the hood doesn't get any warmer than it does when the car is parked in the sun on a summer day. I expect more heat in the summer, and that can't be good for the paint. Never seen a hood warp from lack of insulation, but I guess it might be possible.
I've had the insulation removed from the Miata for 16 years and the paint on the hood looks the same as the rest of the painted metal (but the plastic bumpers are more faded). The S2000 probably generates a lot more heat, so long term paint issues are an unknown at this point.
Old Feb 1, 2006 | 05:36 PM
Jakup's Avatar
Yeah, it seems like sunlight would do more to fading paint than heat from underneath. Again, how does removing the insulator allow more air into the engine bay.
Old Feb 1, 2006 | 07:56 PM
RED MX5's Avatar
[QUOTE=Jakup,Feb 1 2006, 09:36 PM]Yeah, it seems like sunlight would do more to fading paint than heat from underneath.
Old Feb 2, 2006 | 12:23 AM
Lickermat's Avatar
I'm not the one who said it allowed more airflow
That would be me; it certainly does allow for air to flow more under the hood, if you have taken your cover out then you would see why.
The OEM insulation sheet is mainly a 2-3mm sheet with 24mm blocks of insulation that fill the inserts in the bonnet. Remove the insulation you now have that 2-3mm gap all over the engine bay plus the 25mm inserts of space in each of the sections of the bonnet...
I think its fair to say this is spare air space
As to bonnet heat and cracking the heat that is generated is no where near enough to cause cracking. It gets warm but that again is not a bad thing as its taking the heat away , by removing the under insulation you are allowing the air to pass out of the bay rather than become a huge heated pad of insulation which is what it does from stock.
So you could argue that in hotter environments this is only a good thing as the stock insulation keeps the heat in and its sitting over the engine
Guys It
