spoon or mg racing intake
Old Dec 16, 2002 | 06:38 PM
moc8's Avatar
Default spoon or mg racing intake
planning to buy an intake and it comes down to two spoon or mg racing. Which one is better? positives and negative of both. Which one sounds better?
thanks in advance.
Old Dec 16, 2002 | 07:01 PM
S2kRob's Avatar
Well, I've got the MG Racing intake and quite like it. First off, it replaces the entire airbox assembly unlike the Spoon. Second, it is a true CAI but doesn't suffer from the drawbacks of the AEM system. The filter is a panel filter mounted high up. The overall shape of the intake from the point where air goes in to the filter is a funnel. Narrow at the bottom and wide at the top. It simply won't suck in water unless you go through a swamp. If you don't believe me, try sucking a liquid up with your mouth wrapped around the wide end of a funnel. It's also the reason why straws are a uniform cross section (like the AEM). Liquids are much easier to suck through uniform cross-sections than through cone shaped devices, so you really don't have to worry. I've driven mine through lots of rainstorms and haven't had any kind of remote problem.
Plus CF looks great. And the sound is superb. And the power is very consistent. I love it, would recommend it, try to find a used one. Install time was 45 minutes.
Old Dec 16, 2002 | 07:11 PM
moc8's Avatar
rob, how is the filter element and where did you buy it from.
thanks
Old Dec 16, 2002 | 08:53 PM
Schatten's Avatar
the MG Racing CAI WILL suck up water - a recent experience proved that theory.
its mounted very low - right next to the x-brace in reference to how low it is. it can be great on the track and freeway but otherwise you are sucking up hot air from the hot asphault.
Old Dec 17, 2002 | 07:08 AM
S2kRob's Avatar
[QUOTE]Originally posted by Schatten
[B]the MG Racing CAI WILL suck up water - a recent experience proved that theory.
Old Dec 17, 2002 | 07:46 AM
Schatten's Avatar
4-6" in height can make quite a bit of difference in heat that is dissipated from the pavement. just like a stovetop, the Texas pavement down here boils. when people joke about seeing the liquid state of asphault - well, its quite common down here. the temperature difference does vary that much.
I wish I could chime in on the experience, but the person who this happened to would need to chime in. the water wasnt' that deep and everything else with a CAI of different brands could take it without a problem. puddles with this thing - even the smallest on the right side of the dipping roads - I'd worry.
Old Dec 17, 2002 | 09:11 AM
S2kRob's Avatar
Thanks for the heads up. I guess I should get that J's Racing intake I've always wanted . . .
Old Dec 18, 2002 | 06:02 PM
S2000PILOT's Avatar
[QUOTE]Originally posted by S2kRob
[B]Thanks for the heads up.
Old Dec 18, 2002 | 08:28 PM
AJ PwR's Avatar
My votes good to Spoon. Spoon intake consist of the intake filter and the duct. It keeps the intake temp. down and constant power. PLus it is mych cheaper than a MG intake.
sn0wman
Dec 22, 2012 01:48 AM
g.s2k
Feb 2, 2010 02:50 PM
rcodea
Dec 13, 2006 03:06 PM
DMENACE021
Jan 31, 2002 10:45 PM
gregstevens
Apr 13, 2001 05:22 PM
