spoon radiator hose set
Old Aug 1, 2004 | 03:46 PM
billy_i_vtec's Avatar
Default spoon radiator hose set
hi all,
anyone got anything good or bad to say about this set?
i was thinking of buyng it to add a bit of bling to the engine bay - not for any great practical reason.
ditto with the cf plug cover.
cheers,
billy
Old Aug 1, 2004 | 03:53 PM
terd ferguson's Avatar
I think they are pretty much the same as Samco, but a little more expensive. Both are stronger than stock. $300 for Spoon radiator hoses is a little much, but I'll probably have some before its all said and done.
Old Aug 1, 2004 | 04:49 PM
loi's Avatar
loi
Spammer
it more for dress up accessorices then anything else, i agred, the material maybe better the stock. i have a set on my car, i think it just look better with the rest of the spoon parts in my car
Old Aug 1, 2004 | 04:56 PM
xviper's Avatar
Moving to S2000 Talk.
Old Aug 1, 2004 | 04:59 PM
SilverKnight's Avatar
I'm going to get the spoon radiator cap
Old Aug 1, 2004 | 05:18 PM
Stealth Operator's Avatar
The radiator hose set reduces water temperature, it isn't just a bling item. This should be matched with any 1.3 radiator cap, Mugen/Spoon thermostat and Mugen/Spoon fan switch at least to see sufficient differences.
Old Aug 1, 2004 | 05:23 PM
I can use the 1.3 cap by itself right no need to buy other cooling stuff?
Old Aug 1, 2004 | 08:37 PM
Uncle Fester's Avatar
I did not know that by adding silicon radiator hoses you could reduce water temperature.
It was my understanding that silicon does not break down like rubber does when exposed to the antifreeze / water mixture. Just get the Samco hoses, Samco provides the hoses for Spoon.
Old Aug 2, 2004 | 01:41 AM
SilverKnight - Yes, you can use the 1.3 radiator cap without any other upgrades.
Uncle Fester - My water temperatures show consistent drops after the basic cooling upgrades were done, there is an average drop of 10 degrees at peak compared to before. This is significant and a worthy upgrade.
Old Aug 2, 2004 | 02:28 AM
CrazyPhuD's Avatar
Ahhhhh......ok so I believe that the coolant drop you're seeing is from the new thermostat and fan switch. I don't believe the hoses will have any impact on coolant temperature... However if I am incorrect please explain to me how the hoses can contribute to coolant temp reduction.
