Spoon rear brace
Old Sep 15, 2001 | 11:20 AM
Lawdog's Avatar
Default Spoon rear brace
Does anyone have pics of the Spoon rear brace installed? The sheet I got with the brace is no help.
Old Sep 15, 2001 | 06:24 PM
2x6spds's Avatar
Hi Lawdog
I think it's a straight swap for the stock rear cross brace.
Old Sep 15, 2001 | 06:28 PM
reecespieces's Avatar
Is this a straight bar? If so, then if you look under the car there's a bar that's held up by 6 bolts located right under the differential. The 4 larger bolts are torqued to 33lbs-ft and the 2 smaller bolts are torqued to 7.2lbs-ft
I believe the spoon bar only has the 4 larger bolts.
Old Sep 15, 2001 | 06:37 PM
2x6spds's Avatar
The rear Spoon lower brace is a straight bar, but beefier than stock.
Old Sep 15, 2001 | 06:42 PM
OK, then the torque specs I posted is correct Let us know your opinion on it.
Old Sep 16, 2001 | 06:43 AM
Lawdog's Avatar
Thanks guys, particularly regarding the correct torque figures. I'll put it on today.
Old Sep 16, 2001 | 08:25 AM
cdelena's Avatar
The originals were designed for JDM cars and do not accommodate the evaporative emission gear without drilling. Are the new ones drilled for the installation?
BTW, I did not find any improvement with this particular replacement. Let us know if you think it makes any difference.
Old Sep 16, 2001 | 08:32 AM
2x6spds's Avatar
I agree cdelena, no improvement in structural rigidity or handling. Perhaps a miniscule improvement in acceleration through lightened wallet effect.
[QUOTE]Originally posted by cdelena
[B]The originals were designed for JDM cars and do not accommodate the evaporative emission gear without drilling. Are the new ones drilled for the installation?
Old Sep 16, 2001 | 11:42 AM
joe_s2k's Avatar
I have the same opinion as CDELENA and 2x6spds. This mod does not seem to affect the handling of the car in any way.
Old Oct 8, 2001 | 02:37 PM
jpotts's Avatar
so how did the installation go? take off old, put on new? any drilling necessary?
thanks
