Spoon Sport Stroker kit
Old Feb 3, 2006 | 02:56 AM
S2000_Europe's Avatar
Default Spoon Sport Stroker kit
I saw this at Spoon web page it is in Japanese so I do not understand almost nothing, but What I could figure out is that makes 275 ps and rev limit of 8.600
but the price 155.000 yens!!!! $1400 for a stroker kit? if someone knows japanese....
http://www.spoon.jp/jp/topics/2005122002.php
More services at Spoon Shop
http://www.spoon.jp/jp/topics/2005122001.php
NA lovers do you see the light at the end of the tunnel?
Old Feb 3, 2006 | 05:11 AM
Jakup's Avatar
$1400 doesn't seem like much for a forged crank, rods, and pistons in a stroker kit, especially from Spoon. How is this stroker kit making so much more power than the F22 though?
Old Feb 3, 2006 | 05:14 AM
Triig's Avatar
Try this
http://babelfish.altavista.com/
Old Feb 3, 2006 | 05:32 AM
it makes 30 hp more, but also revs 600-700 rpm more, but other factor should be taken into consideration apart of higher rev limit
Old Feb 3, 2006 | 05:38 AM
Originally Posted by Triig,Feb 3 2006, 04:14 PM
thanks
and yes it cost 155.000 yens, I did not undestan the to last lines:
You receive, also cylinder single unit processing such as boring, horning/honing and cross mesh processing which adjust the cylinder to each piston. ツ・73,500
Old Feb 3, 2006 | 05:50 AM
S2KBreaker's Avatar
Drool...
Old Feb 3, 2006 | 09:20 AM
steven975's Avatar
aftermarket kits are also rated very liberally.
take a look at car and driver's supercar challenge for proof. You see cars rated at 400HP and up not even matching the times of a stock S2K.
Old Feb 3, 2006 | 09:21 AM
ej0513's Avatar
i thought they stopped selling this product due to its unreliability.
Old Feb 5, 2006 | 08:31 AM
Silver9k's Avatar
my guess is that if it is near 275hp then maybe the motor had other spoon parts in it, and it was also rated at the flywheel. In that case, I'm just about there already with my small array of parts. As at 225whp it is about 270bhp
but either way, that does seem tempting at such a low price. Main draw back is cams however, only company that really makes them is Toda, and you need other Toda parts to use them
Old Feb 5, 2006 | 09:57 AM
toda cams does not make more power than stock, and you can use other stroker kits with toda cams just need to check clerance.
