Spring Cleaning - a bit early
Old Feb 20, 2006 | 01:24 PM
AgentOrange's Avatar
Default Spring Cleaning - a bit early
It's time to change my fluids and I wanted to change my Oil, tranny and diff fluids all at the same time. I don't have a garage or driveway to do it myself, so I will need to take it somewhere to be done.
Couple questions.....
1. How much would the estimated cost be for these three items?
2. How long will it take? (do I need to drop off the car for the day or just wait it out?)
3. Any advice on what to specifically ask for? (my first fluid changes on the S) Or should I bring my own stuff?
4. Should I do this at the local dealer? (or are other places more cost effective?)
Thanks guys,
Old Feb 20, 2006 | 01:28 PM
s2kv's Avatar
Dont know if yout want to bring it to the dealer, but I do know you should bring your own fluids because dealers have been known to put the wrong fluids in. GL
Old Feb 20, 2006 | 01:46 PM
S2kracka's Avatar
If there is a dealership nearby that would work. Bring your own rear diff fluid (LE-607 is great stuff aslong as the car doesn't get driven in temps below 40 too often, otherwise Mobil 1 75W-90 is fine for any weather). Let them use their engine oil (Mobil DriveClean) and tranny fluid (Honda MTF). Also, make sure they get new crush washers on the drain and fill bolts. Aslong as they begin working on the car right away it will take less than an hour.
Old Feb 20, 2006 | 02:45 PM
aronparsons's Avatar
Other things to consider if you can't recall the last time they were done is brake fluid and clutch fluid; a full flush should be in order if it's been 3+ years.
Old Feb 20, 2006 | 06:14 PM
RotoRooter's Avatar
ask your local s2kers to help u with the fluid change
Gamma S2k
San Diego S2000 Owners
Mar 28, 2009 09:08 PM
s2k_PikeStyle
Jul 16, 2005 01:34 PM
haninman
Sep 17, 2004 11:51 AM
TunedS2000
Aug 21, 2004 06:52 AM
Nicotunes
Aug 15, 2004 02:25 PM
