spring questions
Old Apr 4, 2004 | 06:28 PM
BaDa$$rIo's Avatar
Default spring questions
do most people replace struts? how much to get the springs compressed? easy to instal? any one have favorites
Old Apr 5, 2004 | 03:12 PM
BaDa$$rIo's Avatar
come on help me out
Old Apr 5, 2004 | 03:23 PM
ninegrand's Avatar
Do a search on spring install. I can't find the thread, but a number of us have posted on "how-to", tips, pics, etc in the thread I am thinking of. In fact there are a few such threads.
You will also find a great deal of info and opinions regarding brands/styles.
FWIW, we have shocks not struts
Old Apr 5, 2004 | 03:25 PM
ninegrand's Avatar
Ok so I looked just a little harder and found several, here is one
http://forums.s2ki.com/forums/showthread.p...&threadid=66520
Old Apr 6, 2004 | 10:37 AM
Hockey's Avatar
We have struts. When I went to get the spring compression tool from Autozone, I accidentally checked out the "Shock" kit and I can tell you - no dice. That tool requires you to place the compression tool down the CENTER of the spring, with clamps extending toward the perimeter. The "Stut" kit on the other hand, attaches to the OUTSIDE of the spring.
When the spring itself sits on a "perch", or cup, with the shock.......you have yourself a strut.
The job itself is 1/2 a day, DIY, rented strut compression tool, and an alignment within a week.
Many spring choices out there depending on what you need. Do a search for Eibach or Espilar or KG/MM.....
You may chose to replace your strut at the same time, or re-use the stock ones. Just be warned that it is the same procedure to do the struts, so you'll end up doing the same job twice if you decide later.
Helps to have a buddy, too.
icecreamballer
Jun 30, 2005 01:07 AM
RT
Jan 10, 2003 11:22 AM
