Sputtering, stalling, hesitation...SOLUTION.
Old Aug 11, 2007 | 04:47 PM
rnye's Avatar
Awesome - thanks!
Old Aug 11, 2007 | 09:33 PM
J's_Racer's Avatar
awesome thanks man , the forum is great to have guys like you. thinking like and engineer
Old Aug 12, 2007 | 11:04 AM
tawheed's Avatar
if this works - this has gotta be a sticky considering how many threads there about this exact issue!
Old Aug 12, 2007 | 12:29 PM
CKit's Avatar
Yeah, it was striking how many people were having the problem despite MAP whacking and gas tank fuel injection cleaner treatments.
I can tell you, it's super frustrating to not have a "clean" running car.
Old Aug 13, 2007 | 08:31 AM
db17k's Avatar
I just took off my throttle body and cleaned the WHOLE thing, acceleration is smoother and hesitation is gone, but i've still got a rough idle. so this isn't the end all fix for that, as you know by reading the other thread.
Old Aug 13, 2007 | 09:50 AM
CKit's Avatar
Yup, it's just a "rule out" when everything else has been checked and replaced. And since it's so easy, I'd do this as one of the first things to take it off the table.
Old Aug 13, 2007 | 09:58 AM
Silkky's Avatar
Great information
Old Aug 14, 2007 | 03:31 PM
millertown15's Avatar
Hey, I tried this and my problem still occurs. Good thinking though, and thanks for the information.
Old Aug 14, 2007 | 06:12 PM
S2KPUDDYDAD's Avatar
Mine was giving me an issue and I cleaned it out too good info
Old Aug 16, 2007 | 09:08 AM
Jasonoff's Avatar
Banned
Interesting.
I have an issue where i can not get on or off the throttle smoothly and have some hesitation at low RPM (it's not my driving ). If I'm coasting at high rpm it's impossible to ease back onto the throttle. Or if i am on the throttle it's very hard to let off smoothly.
Air filter is clean
Plugs are fine
Coil packs are fine
Throttle cable is fine
Whacked my map
Tried someone else's map
My TPS tests out ok.
I did clean my TB but neglected this area.
Fuel system cleaner helped
My next step was to pull the injectors and have them tested\serviced.
I'm going to remove my TB again and clean the crap out of that area.
