SRS IS ON ! HELP
Old May 29, 2008 | 08:29 AM
J_STATUS's Avatar
Default SRS IS ON ! HELP
THE PREVIOUS OWNER HAD AN AFTERMARKET STEERING WHEEL, SO WHEN I PURCHASED THE CAR THE OEM WHEEL WAS CROOKED, SO I UNSCREWED THE AIRBAG TO GET ACCESS TO THE BOLT TO ADJUST, SO NOW ITS STRAIGHT AND PUT EVERYTHING BACK, THEN MY SRS TURNED ON.... ANYONE KNOW WHY?
Old May 29, 2008 | 09:06 AM
Mr. Eryozgatliyan's Avatar
Banned
WHY THE HELL ARE YOU YELLING????
Old May 29, 2008 | 09:28 AM
REVHIR's Avatar
AHHHHHH!
Old May 29, 2008 | 11:43 AM
bullitt5897's Avatar
did you reset the ECU? take the power off the battery let sit for 15 min and reattach battery and see if it goes away...
GL and hope it helps
Mike
Old May 29, 2008 | 12:19 PM
SheDrivesIt's Avatar
I may be wrong but I seem to recall that there is a separate SRS system reset.
Old May 29, 2008 | 06:17 PM
AnkitSid's Avatar
http://forums.s2ki.com/forums/index.php?showtopic=135685/
there you go
Old May 29, 2008 | 06:19 PM
AnkitSid's Avatar
there you go
Old May 29, 2008 | 08:43 PM
orange_chicken's Avatar
LOUUUUUD NOISES!!!!
Old May 30, 2008 | 06:34 AM
Nate4635's Avatar
Yea, that link should do it. I had the same problem... ECU reset will NOT reset the SRS light. I just used a wire, did not buy that service tool (as all it is is a jumper basically)
loftust
Mar 19, 2009 10:40 AM
neoarroyo
Jul 16, 2007 09:51 PM
em-Series s2000
San Diego S2000 Owners
Jun 14, 2007 03:08 PM
TunedS2000
Jun 9, 2004 09:57 PM
