SRS light help?????
Old Feb 12, 2004 | 06:20 PM
rodgozinya's Avatar
Default SRS light help?????
ok i just put in my new steering wheel and i knew i would have a SRS light but i was dumb enough to sell my OEM steering wheel and i have to get my car inspected...
i know ill be ok with the steering wheel but not with the light is there anyway to turn the light off???
s2kmugen's Avatar
isn''t there a fuse for the SRS light?.. I 'm not sure though
Old Feb 20, 2004 | 04:20 PM
rodgozinya's Avatar
does anyone else know about a fuse or anyother way to turn off the SRS light???
Old Feb 20, 2004 | 05:39 PM
Slows2k's Avatar
Putting the airbag back in is your best bet. I beleve there are some steering hubs that come with a resister to fool the control unit into thinking an airbag is attached. I wouldn't go probing any SRS wiring, you can cause more damage than your trying to fix. I still reccomend the stock wheel and airbag.
Old Feb 20, 2004 | 07:03 PM
BlueS2000Boy's Avatar
even removing your belts will set off your srs light. i have that problem but don't mind that much. without a doubt you should either buy a new hub or find a wheel to borrow
Old Feb 20, 2004 | 11:51 PM
Quik S2K's Avatar
put a peice of black tape over it. Then you dont have to worry about it in your face
OTher then that, I dont think there is a fuse. Borrow someone's wheel or get a new hub.
Old Feb 21, 2004 | 05:41 AM
3ngin33r1's Avatar
pull the bulb. of course you'll have to have the dash ripped apart to get to it.
zakazak
Mar 31, 2014 04:58 AM
shotgun2224
Mar 20, 2012 10:30 PM
Lttakas
Oct 16, 2009 12:46 PM
fadiss2k
Jan 1, 2006 05:15 PM
S2000AD
Jul 25, 2005 02:27 PM
