Steering Effort Increased after lowering?
Old Mar 24, 2009 | 03:07 AM
starchland's Avatar
Default Steering Effort Increased after lowering?
At times, the car needs increased steering effort to keep it tracking straight, alot of times when the road has a crown in it but also other times too (maybe just not noticeable).
Is this just a negative characterstic of lowering springs (Changed suspension geometry) or can it be fixed via alignment settings or new tires. There is a bit of camber wear on my front passenger tire so I think this may be the problem. Im wondering if most of you on a 1" drop have experienced this? is this a common problem?
Old Mar 24, 2009 | 04:04 AM
Rodney's Avatar
you need to align the car because it most likely has excessive toe out from the lowering. that is what is causing your "camber" wear, from the toe out tire scrub.
Old Mar 24, 2009 | 05:25 AM
Saki GT's Avatar
Need to re-align the car, fix caster.
Old Mar 24, 2009 | 08:16 AM
GPW AP2's Avatar
After my Tein S-Tech my alignment was way off! After I got it aligned it felt great!!
John
Old Mar 24, 2009 | 09:53 AM
starchland's Avatar
Alright good to know, I guess what I was asking is...can my car feel factory/stock even with it being lowered 1". Will look into getting her aligned and possibly new tires.
Old Mar 24, 2009 | 11:46 AM
IrishS2k's Avatar
I'd like to know this too. I've been considering these springs with stock shocks.
Old Mar 24, 2009 | 11:49 AM
GPW AP2's Avatar
I did not notice any difference when I installed them on my AP2, except the car was lower.
John
Old Jun 29, 2009 | 12:30 PM
starchland's Avatar
got an alignment seemed to correct things a great deal. road manners improved. however the steering does feel a bit heavy on the highway, and im not sure if this is normal (comparing it to say a 7th gen accord) however when the car is going straight the wheel is a tad crooked so it will be going back as that is one of my pet peeves.
Old Jun 30, 2009 | 01:25 AM
foxy_s2k's Avatar
The steering does stiffen at speed, it's a design feature to prevent accidental swerving at 80mph.
Old Jun 30, 2009 | 12:37 PM
starchland's Avatar
good to know and keep in mind thank you.
