Steering Wheel Play
Old Mar 28, 2003 | 11:38 AM
mns2k's Avatar
Default Steering Wheel Play
What is the allowable steering wheel play in a MY00?
Old Mar 28, 2003 | 04:12 PM
wanabe's Avatar
from the service manual:
page 17-4
rotational play : 0-10 mm (0-.39 in)
not much- mine is closer to 0 than it is to 10 mm!
if more than that, the rack guide should be adjusted...
Old Mar 28, 2003 | 06:37 PM
Barry in Wyoming's Avatar
When mine had too much wheel play after my engine was repaired, it took only a couple minutes for the dealer's mechanic to fix it.
Old Mar 30, 2003 | 02:47 PM
mns2k's Avatar
After I have the TSB for the 1-2 grind fix done the my S came up with about 5 mm of play. I don't like it at all.
Do you know the dealership will not adjust back to zero as it was prior to the TSB being done. Do you know what the dealer "fixed" to make the play less?
Thanks
Old Mar 30, 2003 | 03:11 PM
[QUOTE]Originally posted by mns2k
[B]
Old Mar 31, 2003 | 04:42 AM
mns2k's Avatar
[QUOTE]Originally posted by Barry WY Silver/Black '01
[B]I might have it wrong, but, as I remember it was a matter of applying the correct torque to bolts that hold the steering column on.
ttb
May 1, 2004 09:55 PM
B.C.
Nov 22, 2003 10:31 AM
S2000 Driver
Oct 3, 2002 07:35 AM
A_Wooly
Mar 26, 2002 12:02 AM
wanabe
Jun 8, 2001 11:14 AM
