Stock Alignment Specs and Toe Question
Old Apr 21, 2004 | 07:47 PM
Dj K-otik's Avatar
Default Stock Alignment Specs and Toe Question
Is this correct?
Front:
Camber: - 1 degree (negative)
toe: none
Rear:
Camber: - 1.5 degrees (negatative)
toe (in): ?
Not complete, but is this the factory alignment for my 2001? Also, the S2K comes from the factory with toe IN on the rears, right? A positive (+) toe rating (i.e. 0.28) implies toe in and a negative (-) toe rating (i.e. -0.14) implies toe out, yes?
Any help would be appreciated. Thanks.
Old Apr 21, 2004 | 07:50 PM
ImportSport's Avatar
This spec is one of the commonly suggested ones (not stock):
Alignment: (all numbers with driver in place)
Front camber = -1.75 degrees (or as close as possible, equal side to side)
Front Caster = +4 degrees or as much as possible without losing camber setting
Front toe = 0-1/16 out total
Rear camber = -2 degrees (or as close as possible, equal side to side)
Rear toe =
Old Apr 21, 2004 | 08:03 PM
payneinthe's Avatar
ImportSport, That's way too much camber for a street car. What you've got there is very close to an autocross-only spec.
irock aypee one
Dec 16, 2006 11:46 AM
S2K:-)
Apr 13, 2006 08:31 PM
eraxpres
Dec 4, 2005 05:57 AM
exceltoexcel
May 5, 2004 09:29 AM
