straight pipe?
Old Apr 3, 2005 | 03:47 PM
RRBIV's Avatar
Default straight pipe?
I want a straight pipe but heard that the check engine light will come on. I came across this while searching. Does this sound real? It says..........
Finally....After nearly a year of tuning and testing...
Tech2K
Is releasing our new TEST PIPE and O2 Simulator ECU TOGETHER!
ONE COMPLETE PACKAGE!
This auction is for both a Brand New NO CAT replacement RACE Pipe and an exclusive Tech2k O2 simulator chip!
FITS HONDA S2000 Years 2000-2003! A modification you WILL feel!
Includes ALL bolts needed and install instructions! Everything needed for install!
SAY GOODBYE TO THOSE RESTRICTIVE CATS!
All Tech2K Race Pipes are brand new and feature an exclusive tuned expansion chamber for maximum exhaust flow. Uses OEM O2 sensor insert and extreme temp silver ceramic finish. Made from top of the line rust proof materials.
Flanges are LASER cut for perfect fitment!
This Auction also includes a brand new O2 Simulator unit to keep your check engine light off and to maximize your Race pipes full HP potential!
When the exhaust system is modified on a Honda S2000, the car's ECU (computer) reads that there is an error and kicks your check engine light on. Not only does this keep you from knowing when there is a REAL problem with your S2k but it causes the motor to run rich which is when the ECU dumps extra fuel into the motor to try and correct the problem and safe guard the engine by robbing it of horsepower. So you end up loosing all the HP gained from the exhaust and cat removal.
The Tech2K Eliminator keeps the car running 100% at normal conditions, with or without the cat in place and regardless of what high flow exhaust you choose. It tells the ECU that everything is fine in the exhaust department and it won't interfere with any other sensors (Meaning if there is another problem with the car your check engine light will still go on). This allows you to get the MAX HP possible from your new modifications, worry free!
You still keep the OEM sensor in place, no modifying required to pipe or O2 sensor, just the wiring harness which you can remove later with NO lasting effects.
EASY INSTALL! Comes with complete step by step instructions. If you can get to where the arrows in red are pointing then you can install this Eliminator!
Guaranteed to work and fit!
Above is a before/after dyno of a S2000 with the stock cat and one with a test pipe/straight pipe in place. Almost 7HP TO THE WHEELS! MORE with Turbo/Super charger and aftermarket exhaust!
Old Apr 3, 2005 | 04:14 PM
RRBIV's Avatar
hi everyone, can some says something. 16 views. no responses
Old Apr 3, 2005 | 04:47 PM
afwfjustin's Avatar
I'm not sure but I'm interested in a response too. A straight pipe is probably the first mod I'll do to my S.
Old Apr 3, 2005 | 04:53 PM
papa5murf's Avatar
why not just buy a straight pipe and get an 02 dummy simulator for like 10 bucks...... i have his pm somewhere in my pm box i gotta go look it up....
Old Apr 3, 2005 | 04:54 PM
papa5murf's Avatar
pm "learnerspermit" he makes the little o2 simulator thingies.....
Old Apr 3, 2005 | 05:16 PM
mweig's Avatar
I have a straight pipe.
Old Apr 3, 2005 | 05:26 PM
afwfjustin's Avatar
Is that a joke? After reading your sig I wasn't sure
What brand, how much, and where did you get it? How'd you curb the check engine light?
Old Apr 3, 2005 | 05:40 PM
papa5murf's Avatar
get the t1r test pipe.. it's like 99 bucks.. from www.aj-racing.com .... and for the o2 simulator thingie pm the guy i noted above...
Old Apr 3, 2005 | 06:40 PM
tabach0y273's Avatar
Except I'd just do the mechanical O2 simulator. I've been running it on my T1R test pipe and no CEL. Check out the link below for details on how this cheap mod works!
https://www.s2ki.com/forums/index.ph...opic=229959&hl
Old Apr 3, 2005 | 07:54 PM
xviper's Avatar
This statement clearly shows that whoever wrote it did NOT do his homework. The O2 sensor in the cat only tells the ECU how well the cat is working and what condition it's in. It DOES NOT use this signal to run the engine.
What kind of money are these guys charging for their "straight pipe" and O2 simulator? Like already posted, you can get the T1R test pipe for about 100 bucks, spend another few bucks to make your own mechanical O2 simulator. Don't buy into the hype unless there is a price advantage, ESPECIALLY in light of the stupid statement above.
Lino8419
Aug 5, 2007 07:13 AM
pemex70
Aug 20, 2005 11:38 AM
Swiftvision
Dec 14, 2004 09:01 AM
swtazn97
Oct 28, 2002 02:11 AM
b8b88
Oct 9, 2002 10:23 PM
