stupid question
Old Jul 28, 2010 | 09:01 PM
s2000maniac's Avatar
Default stupid question
what size torque wrench would I needing most if I did maintenance in my s2k. the 1/2, 3/8 or the 1/4? basically i would be doing tune ups, fluid changes etc....
Old Jul 28, 2010 | 09:03 PM
s2k dre's Avatar
3/8 is perfect because ur not gonna be torqing more than 100 ft lbs.
Old Jul 29, 2010 | 04:47 AM
tiger1964's Avatar
NOT a stupid question, and I've seen some dueseys here.
Old Jul 29, 2010 | 04:59 AM
whiteflash's Avatar
One of the best questions asked actually
Old Jul 29, 2010 | 05:35 AM
Mike21's Avatar
i use a 1/2" torque wrench. nothing on this car it can't handle.
Old Jul 29, 2010 | 08:09 AM
Woodson's Avatar
No, a stupid question would have been what colour torque wrench to buy.
Old Jul 29, 2010 | 02:25 PM
rmc22's Avatar
+1 for 3/8
You can pretty much take apart and build a Honda with a handful of metric sockets and a 3/8 drive ratchet.
My old torque wrench was 1/2 and I spent more time looking for an adapter than I would actually using the tool.
Old Jul 29, 2010 | 09:09 PM
JDMQuip's Avatar
3/8 torque wrench, 17mm socket for oil drain and tranny drain, 23, 24mm for diff drain and fill.
Old Jul 29, 2010 | 09:28 PM
ans2k's Avatar
3/8 would be great. only rarely do you have to go above 100ft-lb. like rear axel nut. the only reason why i have a 1/2 is because this was the only size that came in ft-lb and the othe one was 3.8 but it was in in-lbs. which was the max on 57 or 47 ft-lbs.
Old Jul 29, 2010 | 09:52 PM
Arcoril's Avatar
Also, regardless of which wrench you end up with, try to get 6 point sockets. I once ended up rounding off an overtightened oil drain bolt with a 12 point socket + breaker bar.
