stupid windshield washer squirters
Originally Posted by mrmumbels,Dec 27 2005, 12:33 PM
Is there some kind of fix for this?
Remove the lines from the OEM spray nozzles and then install another set of spray nozzles under the hood by the windshield.
This way the spray does not cross your hood.
I've seen it done and it works great.
simple mod too.
Originally Posted by SIIK2NR,Dec 27 2005, 02:52 PM
Actually there is...
simple mod too.
simple mod too.
Originally Posted by r_duff,Dec 27 2005, 03:16 PM
good idea, but wouldnt that leave holes on your hood?
You only disconnect the lines from underneath the hood and reconnect the lines to the actual nozzles that you installed in the new location.
simple mod too.
simple mod too.
I don't quite understand the issue. Living here in the Sun Belt, I rarely use the windshield washers. When I lived in Massachusetts, I would go through a couple of gallons per winter. They would be used when my windshield was covered with road salt, and grime, and I would hardly care about a couple of water spots.
The spots on the hood to care about are those that are dropped from high above by totally inconsiderate birds.
[QUOTE=SIIK2NR,Dec 27 2005, 03:39 PM] You don't take the OEM nozzles off the hood.......you leave them their for cosmetics...
