supercharger performance
Originally posted by stook29k
Does anyone have any 0-60,1/4 mile,dyno #'s on a properly performing S/C S2000? Are all the real world problems solved?
Did a search as suggested by silver surfer but I still can't find any times.
If its any help I remember the simulated times to be a 12.6 in the 1/4 and 0-60 was like 4.8 not too sure on the latter but those are under optimal conditions/driver.
Im also waiting on the real times . . .
Uh...modified? well very little. If you don't count the boost controller and shoulder belt pads
, she's pretty much at stock HP.
Yep, all VR-4s are fat, slow bitches. I suggest you go run one down today.
Nah, she's pretty quick, the big deal is the launch. Most VR-4 drivers (using the term "drivers" very loosely here) have trouble launching, and either burn up their clutch, or in most cases, bog their engine...that's a real bitch.
If you haven't seen an AWD launch at 7,200 RPMs, you haven't lived...it's frickin' bad arse (from what I've heard). I have yet to see one.
, she's pretty much at stock HP.Yep, all VR-4s are fat, slow bitches. I suggest you go run one down today.
[QUOTE]
Poseted by Wesmaster:
Running on aftermarket Potenza SO2 PP's that only had about 2,000 miles left on them (not very grippy at all) I pulled a 13.7 1/4 mile with a 5.1 0-60. The launch was always difficult with the tires. Newer tires will make a difference, they come in this week and I'll GTech again. I plan on upgrading to 18's with Goodrich's like Comptech is currently running. Those should stick better.
