suspension advice
Old Jan 7, 2008 | 12:44 AM
dyhppy's Avatar
Default suspension advice
anyone have an opinion on the best improvement in handling without losing ride quality?
Old Jan 7, 2008 | 04:07 AM
Ks320's Avatar
I wish the CR sits a bit lower
Otherwise, everything else is hard to say. Every track's different and require different settings. Obviously coilovers give you more adjustability. But for me, I would be happy with CR if it sits 1/2 inch lower
The CR's rear suspension (shock/spring combo) is actually quite a bit softer compared to the front suspension (and other aftermarket setups). I would imagine that it would be a bit more easier to drive and have more grip under imperfect road conditions?
Old Jan 7, 2008 | 04:52 PM
RadioZero's Avatar
you will lose ride quality with the CR suspension. best way to describe it is that it makes an AP2 fell like an early AP1. it's a great upgrade but understand that it gets bouncy during road undulations.
i recommend it if you know what you're getting into, If you think it's going to be better without sacrifice, forget about it....
Old Jan 7, 2008 | 05:04 PM
SoMe0nE2tAlK2's Avatar
I thought my old civic slammed to the ground was stiff up untill i test drove the CR. This thing gets bumpy.
Old Jan 7, 2008 | 07:42 PM
Ks320's Avatar
CR is around 7k in the front, and around 4.5k (give or take some). Where as aftermarket coilovers typicall run well over 9kg/mm in spring rates.
Old Jan 7, 2008 | 07:47 PM
Fastfour's Avatar
Is it lower at all or just stiffer?
Old Jan 8, 2008 | 12:31 AM
iam7head's Avatar
Front Rear
OEM 00-01 218 291
OEM 02-03 240 230
OEM 04-07 256 207
OEM 08 274 225
OEM CR 375 264
stolen from the other thread
Old Jan 8, 2008 | 12:48 AM
minimebang's Avatar
compare with the MYs, 02-03 got the most average rate between F&R..(yea, mines is a 03 )
but wait...wth with the front of the CR? 375???? thats even more than aftermarkets...
Old Jan 8, 2008 | 02:19 AM
Ks320's Avatar
The more "intense" aftermarket ones (Buddy Club, Tein RAs, Bilsteins PSS9?, etc)run more than 375 ft-lb ... (and a much stiffer rear). Check out A&J's car (Front 16K, rear 14K). KW V3s run about 9k if I remember correctly.
Anyway, here is a conversion table from ft-lb to kg/mm:
http://spda-online.ca/modules/tinyco...ite/tc_17.html
Kyushin
Jul 6, 2012 07:10 PM
blacknboostn
Dec 15, 2010 08:13 AM
08s2000CRbackinblack
Jun 25, 2009 08:42 PM
D2k
Jan 28, 2009 06:36 PM
samura1
May 3, 2008 06:26 AM
