suspension qustion
Old Mar 28, 2009 | 11:22 AM
moonsoul's Avatar
Default suspension qustion
If any one can help me, when I make a right turn about 90degree corner and my car starting to wabeling on the back about 40mph. I'm not sure i think is the shock but give me some advise.
Old Mar 28, 2009 | 02:53 PM
jeffbrig's Avatar
wabeling????
I have no idea what you're trying to describe....
Old Mar 28, 2009 | 03:09 PM
bgoetz's Avatar
If you are making a 90 degree turn @ 40mph and your rear end is doing goofy stuff, it is pobabally because at that speed the car is sliding sideways. Don't worry you are just about to pull a bit of drift action into the curb .
Old Mar 28, 2009 | 04:21 PM
Artric's Avatar
Unless you're on a perfectly flat surface, like a skidpad, your tires would move with the road, bumpity bump.
I guess you could get a bigger rear swaybar to try and keep them planted. If you go around corners at 40MPH all the time, then I'm sure you can handle it!!
Old Apr 2, 2009 | 07:50 AM
Ks320's Avatar
Sorry ... Sounds too vague and hard to diagnose here
Could be something simple as uneven tire, unbalanced tire, alignment issue ... all the way to a bend frame or blown shock
Take it to a trust worthy mechanic or even another member here for a ride (or ask them to drive your car) ... good luck
H10NDR
Apr 27, 2019 01:18 AM
bmxer882x
Jul 25, 2012 05:22 PM
ryanswhites2k
Jul 10, 2009 02:46 PM
txchopper5
Jan 30, 2009 10:39 PM
P5744D
Aug 10, 2007 08:24 PM
